Is there a way to force a new line in the Preference title?
Subject pretty much says it all.
For instance:
What would really be cool but I'm guessing its not in the cards is:
A text box the is shown when you mouse over the preference description.
John
For device drivers, the HTML encoding of "\n" doessn't work unfortunately.
Also, are you using both fields available: Title and description? It appears that you are only using one.
That should automatically give you at least two separate lines. One other thing, since you are entering a default value, is it important to list the default value in the text as well? Since it is the value that is entered, I would assume people would know it's the default. It is also possible to include a preferences tile that is just text, using the paragraph function.
You can use the html "< br >" (without the spaces) i have used that in a few drivers
Cheers
Thanks... that works :slight_smile: :slight_smile:
Its always a question in my mind whether I should respond saying thanks or just check the like emoji and in this case check the solution box.
