Is there a time or a clock device?
I want to be able to set a time device with Alexa that then a rule can use as a trigger.
Is this possible...?
Basically, setting a wake up alarm time...for the next morning.
With Alexa Plus, you can ask for a specific switch to be turned on at a specific time. You could use this feature to do what you want by having Alexa turn on a hubitat virtual switch, and use Hubitat rule to do something when that switch is turned on.
Thanks...that my be my only solution...but I have kept all control in Hubitat to try to make it easy to manage...hoping there is a way to do this...
I don't know if this is possible with Alexa. But it is definitely possible with Siri.
Hubitat supports a "DateTime" variable. And I use an Apple Shortcut or a Siri command to set the value of that variable.
Then I have Hubitat automations that are triggered when the time has the value of that DateTime variable.
For example, I can set the value of the variable via an Apple Shortcut or Siri to be 05:45. And then my Hubitat automation will trigger at 5:45 AM.
Quick question out of curiosity... :thinking:
If you have a RM Rule configured to Trigger based on the time becoming the same as the value of the hub variable... What happens to that trigger if you change the value of the variable while the trigger is already waiting?
  • Does the rule subscribe to changes of the variable used in the trigger and thus automatically get updated?
  • Or does the new time stored in the variable only get used the next time the rule fires?
Just wondering...
This. Whenever the variable updates, the time the rule fires updates.
Nice! Thanks for the info!
Is The PROVIDED INPUT something I should select from actions? I have just been typing it in.
No, it has to be selected from the list of variables. As seen in this screenshot:
Your approach of creating a new variable out of the input also works.
Aah, now I see where it is. Thanks for the help.
All good stuff. I think for me the way to handle this isn't anything permanent...since the time I want to set varies. While I find it odd the isn't an updatable "time" device...while not creating a routine on Alexa...For what I need...I can just tell Alexa to turn on a device at time "'x"
Thanks!
FWIW, the Apple Shortcuts permits exactly that. Each time the shortcuts is executed, a different time can be set.
Before we go to bed, we can set our Hubitat-based alarm with a simple voice command, "Hey Siri, Alarm Shortcut". And then provide the time when prompted.
In @j715's example - each time he runs his shortcut, his fan will run for a different number of minutes as determined by his input.
Alexa Plus may permit this type of flexibility. Essentially, any system that permits a voice input of time or any number and sends that to Hubitat permits this.
One thing I’ve noticed. I can verbally use a Siri command on my phone to Ron the shortcut and it works fine. If I try from one of my pods it says something about personal but I checked everything and it all seems fine. But no problem as I usually have my phone anyway.
Since I do everything else via Alexa it is probably the way I'll do it...great to know the shortcut stuff. The only one I use now just turns on/off my BT once daily since on my iPhone MAX it gets a bit flaky working with iBeacons after a while if I don't.
