Json local endpoint restart versus settings page reboot.
At one point the restart didn’t fully clear out clear out everything, and would lead to a hub crash.
That makes it clear, using HubInfo to restart with the json call, starting reciently, memory had been never showing the large amount of free memory i was used to.
Just starting low, and plummets turning it in to a cyclic nightmare.
Is it as simple as changing restart to reboot in the json call?
Http://10.0.0.xxx:8080/hub/restart
To
Http://10.0.0.xxx:8080/hub/reboot
That should work unless you have hub security turned on.
BTW - Hub Info doesn’t do a restart, it has a reboot or a shutdown.
And it is one fine device!
Thank you, for this help, and very much for HubInfo.
Thank you again, @thebearmay, this has made a world of difference in the last day.
Much more memory available on reboot than restart.
I believe restart refers to the Java VM in which the hub platform runs.
Reboot refers to the underlying Linux OS running the Java VM.
So restart just kills and restarts the jvm and reboot is a full reboot. Which is really recommend for low memory i believe all of us have been doing the former.
From memory it was when there were mass slowdowns and the team couldn't work out why. As a way to investigate and to not have to fully reboot the device they brought it in.
The rebooter app had that function added from a request from Victor from memory as a example.
This brings me to the question...
What is the best way, using RM, to accomplish a reboot.
Syntax if possible!
