I have two dimmers on my wall. 1 light and 1 fan, but I keep losing the picos on my bed. Is there a bigger remote solution to control 2 lutron dimmers? Thank you
Maybe get a Pico stand?
You mean like a jumbo sized Pico?
Have you used or tried Pico table stands?
What about putting a velcro Command Strip on the back, and sticking it to the bed or something?
I use the Pico pedestals or Velcro command strips to attach the Pico to the headboard or nightstand.
You can also use any button device that’s compatible with Hubitat to control your Lutron Caseta lights that are integrated with Hubitat.
Yes, that’s what I planned on, I just can’t find one
If you have a bedside table within reach, pico pedestal sounds like a good option.
I stick my picks to my nightstand but if you are looking for something hand held these are nit a bad candidate
RGBgenie Remote and Dimmer, ZigBee 3.0, 5 Zones, On/Off and Brightness Control, Factory Reset Option, Works with Hue. RGBgenie ZB-5001 https://smile.amazon.com/dp/B07GBK3KPS/ref=cm_sw_r_cp_api_glt_fabc_TB598V677NC6QPYKJN30
I have my handheld Pico remotes mounted in a switchplate cover. However, to do that, you have to have the mounting bracket that comes with the Pico to mount it in a switch box.
