In Webcore there is a trigger function called, "Is Now and Stays for (time)". Does anyone have a suggestion for implementing that in a RM rule?
The trigger could be "is now". In the actions, I would have a delay for the desired length of time, and then use either a simple conditional or a conditional to test for the value.
Thanks. I just wanted to make sure I hadn't missed something defined this way already. I'll give your suggestion a try.
I would also use a Private Boolean to ensure that there aren't multiple concurrent triggering events because the sensor value changes frequently.
In Rule 5.0, there is also "Wait for condition" and a "use duration" option. Used together (and with an appropriate trigger, depending on what you need for that rule--likely the "is X" thing you mentioned originally), this would also do what you want.
Thanks for pointing this out. I overlooked those recent changes in 5.0
