Hi there, I was setting up my C-7 hub this morning. It appeared to go without an issue. I was able to register, connect to the cloud, and download drivers for the only device I was trying to set up: konnected.io Otherwise, I didn't set up anything on the hub.
Several hours later I had set up konnected and wanted to link it up. I found that the hubitat hub was offline. I checked the router and the hub still shows up and takes up an IP address. I'm able to ping this address. However. the web interface is gone, I get 192.168.2.54 refused to connect. Port :8081 also doesn't give me anything. No lights on.
I had the device plugged in to an UPS but didn't realize that it was plugged in to the non-battery side. I may have switched power off where the UPS was plugged in because I couldn't figure out which switch my security system was on. Could a power-loss have bricked it?
