Is it possible to disable (and then enable) a device (motion sensor/ door sensor), from a rule?
I don’t know what happens when you check the box to disable the device in the device screen… but that can be done programmatically witching rule machine.. I would image the device will still send the commands, but I don’t think the hub interprets them.
I don’t know if this will best said requirements
