I keep getting a corrupt database found when running this endpoint: http://192.168.0.90/brokenDatabase and even after doing a soft reset and before ever restoring a backup I still get the error.
This is on a C5 on the latest platform and even on older platforms, as I thought the update might fix it. BTW the hub runs okay, not much on it.
Also happens with my dev C7 on the latest platform, but my C4 & C7 production hubs are fine, no corrupt DB message
Even when I do a backup and restore I get the same thing
I have a document from some years ago where a collection of endpoints was published. I'm not certain if it was official.
Here's one example: C-8 inexplicably went offline this morning
Going to this page doesn't test anything, which it sounds like is what you're assuming. Itβs just going to show you that message. Going there manually is one way you can do a soft reset (an option on that page) if you can't some other way for some reason.
This is normally just some place the hub would take you on its own, and that should be pretty rare given ways it can recover from this. Or to answer the original question: no, it is not broken.
It's odd, not all of my hubs displayed the corrupt database message, so in failing to read the whole post, I ASSumed the message was valid, I was wrong, sorry guys, fixed the title.
