Looking at Zigbee RGBW controllers. Candeo say their 5 in 1 Zigbee controller (model C-ZB-LC20) 'Works with Hubitat'. On their website they have five individual drivers for it - one per mode, however of the five url's only one (for dimmer mode) works. The other four give a http error. I've reached out to them via support ticket but in the mean time was wondering if anyone here has used them.
Their product:
Looks identical to the ones made by GLEDOPTO; e.g.,
@Candeo_Smart are in the forum, they could probably advise best…
Ah I do now recall seeing that post.
@Candeo_Smart - please fix the dead links for your Zigbee 5 in 1 Hubitat drivers.
The links have been updated. Thank you @johnwill1 for raising this issue.
@Candeo_Smart - I got the device today, so some feedback after connecting it to some existing BTF-LIGHTING 5050 RGBW RGB+Warm White(2700K-3000K) 4 in 1 LED strip I have installed.
Pros:
- Nicely designed. Clip terminals for wiring made it a quick installation without faffing around with tiny screw terminals.
- Pairing to Hubitat was straightforward. The unit was found quickly during inclusion.
- Works well/responsive
Cons:
- I'm using RGBW strip with the RGBW driver. Any colour selected is a mix of all 4 LEDs. If I only wanted a colour without illuminating the White LED I guess I'll have to disconnect the white wire, switch to RGB mode and switch to the RGB driver to ensure the colour is correct. The one driver option that isn't available is the option to have two child devices - one for colour using RGB only mix and another for just the White LED.
