Hi All,
I've just spent the past 3 days moving everything from SmartThings to Hubitat and just finding the last few devices which have drivers missing.
I have a Thinking Cleaner addon plate to make my Roomba "Smart", someone on the SmartThings side wrote a SmartApp to control it which works for the most part but it hasnt been ported over to Hubitat yet. Now I'm able to do a tiny bit of coding but not even looked into SmartThings/Hubitat code for the most part so no clue on what changes are needed.
All I really need the below code editing to work on Hubitat, I'm personally not bothered about anything other than a simple on/off switch for the vac.
Can anyone help?
definition(
name: "Thinking Cleaner",
namespace: " ",
author: "Sidjohn1",
description: "Handles polling and job notification for Thinking Cleaner",
category: "Convenience",
iconUrl: "http://cdn.device-icons.smartthings.com/Appliances/appliances13-icn.png",
iconX2Url: "http://cdn.device-icons.smartthings.com/Appliances/appliances13-icn@2x.png",
iconX3Url: "http://cdn.device-icons.smartthings.com/Appliances/appliances13-icn@3x.png",
singleInstance: true)
preferences {
page name:"pageInfo"
def pageInfo() {
return dynamicPage(name: "pageInfo", title: "Thinking Cleanerer", install: true, uninstall: true) {
section("About") {
paragraph "Thinking Cleaner(Roomba) smartapp for Smartthings. This app monitors you roomba and provides job notifacation"
paragraph "${textVersion()}\n${textCopyright()}"
def roombaList = ""
settings.switch1.each() {
try {
roombaList += "$it.displayName is $it.currentStatus. Battery is $it.currentBattery%\n"
catch (e) {
log.trace "Error checking status."
log.trace e
if (roombaList) {
section("Roomba Status:") {
paragraph roombaList.trim()
section("Select Roomba(s) to monitor..."){
input "switch1", "device.ThinkingCleaner", title: "Monitored Roomba", required: true, multiple: true, defaultValue: false, submitOnChange: true
section(hideable: true, hidden: true, "Auto Smart Home Monitor..."){
input "autoSHM", "bool", title: "Auto Set Smart Home Monitor?", required: true, multiple: true, defaultValue: false, submitOnChange: true
paragraph"Auto Set Smart Home Monitor to Arm(Stay) when cleaning and Arm(Away) when done."
section(hideable: true, hidden: true, "Event Notifications..."){
input "sendPush", "bool", title: "Send as Push?", required: false, defaultValue: true
input "sendSMS", "phone", title: "Send as SMS?", required: false, defaultValue: null
input "sendRoombaOn", "bool", title: "Notify when on?", required: false, defaultValue: false
input "sendRoombaOff", "bool", title: "Notify when off?", required: false, defaultValue: false
input "sendRoombaError", "bool", title: "Notify on error?", required: false, defaultValue: true
input "sendRoombaBin", "bool", title: "Notify on full bin?", required: false, defaultValue: true
def installed() {
log.trace "Installed with settings: ${settings}"
initialize()
def updated() {
log.trace "Updated with settings: ${settings}"
unschedule()
unsubscribe()
initialize()
def initialize() {
log.info "Thinking Cleanerer ${textVersion()} ${textCopyright()}"
subscribe(switch1, "switch.on", eventHandler)
subscribe(switch1, "switch.off", eventHandler)
subscribe(switch1, "status.error", eventHandler)
subscribe(switch1, "bin.full", eventHandler)
subscribe(location, "sunset", pollRestart)
subscribe(location, "sunrise", pollRestart)
schedule("22 4 0/1 1/1 * ? *", pollOff)
pollOff
def eventHandler(evt) {
def msg
switch (evt.value) {
case "error":
sendEvent(linkText:app.label, name:"${evt.displayName}", value:"error",descriptionText:"${evt.displayName} has an error", eventType:"SOLUTION_EVENT", displayed: true)
log.trace "${evt.displayName} has an error"
msg = "${evt.displayName} has an error"
if (sendRoombaError == true) {
if (settings.sendSMS != null) {
sendSms(sendSMS, msg)
if (settings.sendPush == true) {
sendPush(msg)
schedule("39 0/15 * 1/1 * ?", pollErr)
break;
case "on":
sendEvent(linkText:app.label, name:"${evt.displayName}", value:"on",descriptionText:"${evt.displayName} is on", eventType:"SOLUTION_EVENT", displayed: true)
log.trace "${evt.displayName} is on"
msg = "${evt.displayName} is on"
schedule("15 0/1 * 1/1 * ?", pollOn)
if (sendRoombaOn == true) {
sendPush(msg)
if (settings.autoSHM.contains('true') ) {
if (location.currentState("alarmSystemStatus")?.value == "away"){
sendEvent(linkText:app.label, name:"Smart Home Monitor", value:"stay",descriptionText:"Smart Home Monitor was set to stay", eventType:"SOLUTION_EVENT", displayed: true)
log.trace "Smart Home Monitor was set to stay"
sendLocationEvent(name: "alarmSystemStatus", value: "stay")
state.autoSHMchange = "y"
break;
case "full":
sendEvent(linkText:app.label, name:"${evt.displayName}", value:"bin full",descriptionText:"${evt.displayName} bin is full", eventType:"SOLUTION_EVENT", displayed: true)
log.trace "${evt.displayName} bin is full"
msg = "${evt.displayName} bin is full"
if (sendRoombaBin == true) {
sendPush(msg)
break;
case "off":
sendEvent(linkText:app.label, name:"${evt.displayName}", value:"off",descriptionText:"${evt.displayName} is off", eventType:"SOLUTION_EVENT", displayed: true)
log.trace "${evt.displayName} is off"
msg = "${evt.displayName} is off"
if (sendRoombaOff == true) {
sendPush(msg)
break;
def pollOn() {
def onSwitch1 = settings.switch1.currentSwitch.findAll { switchVal ->
switchVal == "on" ? true : false
if (it.currentSwitch == "on") {
state.pollState = now()
it.poll()
runIn(80, pollRestartOn, [overwrite: true])
if (onSwitch1.size() == 0) {
unschedule(pollOn)
if (location.currentState("alarmSystemStatus")?.value == "stay" && state.autoSHMchange == "y"){
sendEvent(linkText:app.label, name:"Smart Home Monitor", value:"away",descriptionText:"Smart Home Monitor was set back to away", eventType:"SOLUTION_EVENT", displayed: true)
log.trace "Smart Home Monitor was set back to away"
sendLocationEvent(name: "alarmSystemStatus", value: "away")
state.autoSHMchange = "n"
def pollOff() {
def offSwitch1 = settings.switch1.currentSwitch.findAll { switchVal ->
switchVal == "off" ? true : false
if (it.currentSwitch == "off") {
it.poll()
runIn(3660, pollRestart, [overwrite: true])
if (offSwitch1.size() == 0) {
unschedule(pollOff)
def pollErr() {
def errSwitch1 = settings.switch1.currentStatus.findAll { switchVal ->
switchVal == "error" ? true : false
if (it.currentStatus == "error") {
it.poll()
if (errSwitch1.size() == 0) {
unschedule(pollErr)
def pollRestartOn() {
def t = now() - state.pollState
if (t > 660000) {
unschedule(pollOn)
schedule("16 0/1 * 1/1 * ?", pollOn)
sendEvent(linkText:app.label, name:"Poll", value:"Restart",descriptionText:"Polling Restarted", eventType:"SOLUTION_EVENT", displayed: true)
log.trace "Polling Restarted"
def pollRestart(evt) {
if (t > 4200000) {
unschedule(pollOff)
schedule("23 4 0/1 1/1 * ? *", pollOff)
private def textVersion() {
def text = "Version 1.5.1"
private def textCopyright() {
def text = "Copyright © 2015 Sidjohn1"
