I have an Iris V3 (iL07_1) motion sensor. It works great but I would like to disable the LED flash on motion sense. I'm aware a piece of tape will work but was hoping for a more elegant approach.
I've searched many times for a manual showing the possible parameter with no luck. And MikeMaxwell's Basic Z-Wave device does not have a zigbee counterpart.
I do not believe this is a configurable option on any generation of Iris sensor. If it is, it is not documented as far as I know. Still, a "Basic Zigbee Tool" would be neat--most Zigbee devices do respond to requests for how to do specific kinds of reporting (e.g., when to do a temperature report), which would be nice to have some day.
Yeah, I should add that I actually like the flash now (the Iris v2 before this was the first one I got that did any sort of flash, and it freaked me out for a while--and it's harder to cover up than the v3 since it's the entire lens flashes). It's rare, but when it happens, it's an easy way for me to know if my automation failed because the battery (probably) died without even looking at Hubitat, unless you're not a weirdo like me who now looks at motion sensors when you walk into rooms, I suppose.
