Iris V2 keypad Arming Mode problems
I have 2 Iris V2 keypads with the Centralite Drivers installed for both, everything work with them, On Button arms the HSM as Arm Away, Partial Button arms as Arm Home and have the keypads beep when a contact (door or window) is opened or closed. The problem is I dont want the keypads to do the single beep, I want it to do the triple beeps as I had with Iris. So, I updated to the Iris V2 keypad driver. Everything is working fine, I thought. I get the triple beeps, HSM armed normally. Today I go downstairs, make some coffee and start to go back upstairs and thought, did I disarm the HSM? I walked past the keypad and waived my hand in front and seen that it was lit red, meaning it is armed. So I click on my Dashboard and see that the HSM is in Arm Night mode. I dont have motions armed in this mode nor the Home mode. So I start to play around and found out that with the Iris V2 Keypad driver, both the On and Partial keys arm the HSM in Arm Night modes. I jumped back to the Centralite Keypad driver and the On and Partial work as they should.
I am having this exact same issue! It's very frustrating. However, I can't get my Iris V2 to work correctly with the Centralite Partial for Night and On for Away either. Both Partial and On always arms night for me unless I turn of the option in the HSM to use the Partial button to arm Night. But if I do that then I can only arm Away with the ON button and nothing happens when I use the Partial button.
Can someone please help me fix this infuriating issue...!
Screen Shot 2020-03-04 at 10.13.11 PM|690x183
If you have smoke detectors or leak detectors, slide "Use to disarm all" to off. If you leave it on, it will disarm the alarm as well as these.
Next, go into your apps and scroll down to Safety Monitor. Then scroll down to Configure Arming/Disarming/Cancel Options. Click on what you want Arm Away, Arm Home, Arm Night to do.
Now scroll down in that same window and add how many seconds you want for the arming and disarming.
