Recently installed a V1 iris motion sensor. No issues pairing or installing the correct V1 motion sensor driver. After installation it worked as it should, but after a few hours it stops working (detecting motion). Checking threads I see that I do have some lightify and Osram bulbs installed that may be causing interference (although I only have V1 devices, mostly contact sensors and outlets, and have never had interference issues before); this being the case, can someone recommend which connected lightbulbs they are using with their HE that will not conflict with V1 devices? Or is there any other fix to keep the V1 motion sensors working? It is a PITA to have get new bulbs only because 1 motion sensor is not working...thanks!
I had the same problem. Switched to sengled bulbs and re-paied the V1 devices. Everything has been flawless since then.
