I am wondering what the current state of IPv6 support is with Hubitat.
I know it is supported in some fashion as it is used with Matter devices. I also know it doesn't appear to work with the main UI. There are clearly some gaps in support.
I recently got IPv6 fully working with my Unifi network allowing ipv6 prefix for local vlans. I am not really trying to fix anything in particular, just wondering why it isn't more functional for general connectivity.
Dev's have stated that's pretty much low on the totem pole so to speak. The majority of companies and home users don't use ipv6 (despite matter doing so) as their general ip protocol. Until that happens I don't see any changes happening anytime soon.
I don't think that is actually true. I think it is used a bit more then we are thinking.
Pretty much every home today is probably dual-stack. When both devices can use IPv6 it may use it without the user even knowing. That said i do think it is a fairly small number that has IPv6 properly setup to delgate Global IP's on IPv6 from the ISP.
This is also largely a chicken and Egg discussion. That doesn't mean we shouldn't properly support it.
I get the priority though.
I would expect we would see small things as they make improvements. Like start with simiply enabling the Web UI through from the hub. That shouldn't be to hard as long as the http server they are running supports it. Should just be a binding configuration change.
Then maybe enable some API's to work through it. This could just come with th gui, but depends on how the contexts are managed in the HTTP config.
Then maybe work on migrating from using IPv4 to IPv6 for connectivity from Hubitat's servers. That should actually be a tangable improvements for Hubitat in reduced transaction times when talking to the hubs. IPv6 should improve connectivity since it reduces network overhead at the endpoint by removing NAT translation from the process.
Probably last would be getting the communication methods updated for things like standard drivers and such. That has other dependencies that may not be easy to get from external vendors.
I would expect IPv4 should always be there for backwards compatibility.
Ofcourse one thing i didn't address above is the hubdiscovery bit for the Hubitat lookup. That would obviously require some improvement as well to lookup IPv6 as well as IPv4
I get the priority discussion, but don't agree it should be ignored because of percieved usage. I have been having allot of discussions around IPv6 at my office recently. Most of the issues with going with IPv6 is from lack of support, not because the company doesn't want to use it.
