iPad 2 (iOS 9) no longer loads Hubitat web interface after updating to 2.4.3.137 — works fine on 2.4.2.160
Hubitat C7
2.4.3.137
Hi everyone,
I wanted to share an issue I’ve run into, in case anyone else has experienced something similar or found a workaround.
After updating my Hubitat hub from version 2.4.2.160 to 2.4.3.137, I lost access to the web interface from my old iPad 2 (iOS 9.3.5). The hub itself works fine, and I can reach it from newer devices (MacBook, iPhone, etc.), but the iPad suddenly can’t load the interface anymore — it shows a blank screen
It seems something changed in the frontend or JavaScript framework between 2.4.2 and 2.4.3 that older WebKit browsers can’t handle.
I totally understand the focus is on supporting modern browsers, but I use the iPad 2 as a small wall-mounted dashboard — it’s perfect for that purpose. If there’s any way to keep basic dashboard compatibility, or if someone has found a workaround (e.g. specific dashboard link, older UI mode, or browser setting), I’d really appreciate it.
