IOS dashboard Sensor not refreshing
I use my iPhone home screen with a Dashboard shortcut for Hubitat. I've decided that the sensor data on the buttons don't update, even after I kill the browser and relaunch. They continue to show old information when I know it's not true (like, my garage door is open, the temperature...).
Is there a way to force refresh on these? The settings has a refresh advanced option, but I don't think it does anything.
Web page on the computer works but not the iphone.
Thoughts?
I’ve had this issue a while. I thought it was iOS beta causing it, so have never raised it. When I use the cloud link, that seems to be better.
Same here. iOS dashboard data is consistently stale for me.
I've noticed that when I use the home screen shortcuts but when I use the browser to go to the dashboard i can refresh to get it updated. Using the home screen shortcut I've noticed if I click the Hubitat icon in the upper left I can get it to refresh.
Are these local or cloud dashboards and are you using the http link or https link?
In my case, using a cloud link, if I press a button it never comes back from the sending state.
Does the command get sent? What device / browser? Does the device in the hub device details page reflect the change? Can you replicate this with a virtual switch?
The command does get sent, latest iOS. I’ll have to check on the device page and a virtual device.
I'm not sure I'm following here, but I can send commands via the Dashboard on my phone to a device and it updates appropriate for me (eg. I turn on a heater switch, it happens and the tile turns yellow).
It doesn't seem to update when sensors are involved. So my sensor that tells the temperature is stuck at whenever I last used the dashboard. My garage door shows open, even though it's not. That one will get the command to open or close it, but the associated sensor ends up being wrong.
