[INVESTIGATING] C-7 with Blue LED and unreachable
Greetings! I woke up this morning and my automations didn't work and I was unable to access my dashboard/hub. I'm unable to ping the hub or get diagnostic access on 8081/8082. I'm running DHCP but with a static address. There's a solid blue LED on the front and I've performed the network reset button on the bottom and still unable to find it on 'findmyhub.hubitat'.
Any other suggestions or did my hub give up the ghost?
Thanks!
If it is still blue, you may need to reboot the hub.
Fixed! I rebooted my router and this fixed the hub. Not sure how that stopped local automations and kept the hub in blue LED, but it works now. Soon as I walked into my office after performing the reboot and one of my lamps turned on (by motion sensor trigger), I knew I was back in business.
Just as a note, you shouldn't do a dhcp reservation on your router AND a static ip on the hub. Do one or the other. Static if it's outside the dhcp scope, dhcp reservation if within.
You're correct. I have only a DHCP reservation in the router.
Can you PM me your hub's id? I can take a look at the engineering logs, there may be some clues for the root cause there.
Thanks! I tried to send a PM and says I can't send you a message.
Join the Owners group:
https://community.hubitat.com/g/owners
You’ll get permissions to PM and post images.
