👋 Introducing VisualAlert – A Smart Flashing System Designed by a Deaf User for Real-Life Needs
You're absolutely right — and I agree with every bit of that.
I also found that smart bulbs (especially RGB ones) can be unpredictable depending on the brand, command timing, and mesh health. That’s why I included a Custom Pattern Configuration option in VisualAlert, which lets users fine-tune the ON/OFF durations. Some bulbs really need that extra breathing room between commands.
I’ve tested with both Sengled and Philips Hue RGB bulbs. Hue bulbs — especially when used with the Hue Bridge — perform nearly perfectly every time. Sengleds were a bit hit-or-miss with some apps, but after some tuning using custom patterns in my app, I was able to get them to flash almost perfectly as well.
Of course, performance can still vary depending on your Zigbee mesh strength, the number of hops, and other devices in the network — so having that flexibility in timing really helps.
Thanks for sharing your insight — it definitely helps others who are working through the same frustrations!
BTW, I tested this setup with two Z-Wave switches in different rooms and one Zigbee RGB Sengled bulb — all devices ran in parallel as expected and successfully restored to their previous states afterward.
I even tested the Sengled bulb by setting it to one color, then flashing it using a different color — it still restored back to the original color without any issues. :+1:
Tried it on two switches.
When lights already off (no group):
  1. simultaneous works pretty darn close.
  2. single flashing works great. On then off in quick succession.
  3. multiple flashing works great. on off on off done.
When lights are on (no group):
  1. simultaneous works perfectly on the initial off. The on, there is a 1 second delay. This is not a complaint. Just letting you know how it's working.
  2. single flash. The lights turn off, then there is a long 8-10 second delay before they turn on again. I think the the initial 'ON' is getting lost (or inconsequential) because the light it already on.
  3. multiple flash. Same thing about the initial "on" being ignored. Lights turn off, on, off, then delay before returning back on. I think you mentioned that restoration will cause a delay, so that might be expected?
Further testing: multiple flashes work great nearly instantly. It's the restoration to previous state that is taking the extra long time.
Turning off "restore previous state" didn't change the behavior of the flashing or the sequence. Light that was on returned on at the end. Light that was off, remained off at the end.
Thanks for the detailed feedback!
I’ve noticed something similar on my end—my RGB bulbs sometimes have a brief delay before starting the flash pattern, while my Red Series Inovelli switches flash instantly.
Regarding the “restore previous state” option, I actually forgot to link that toggle into the new restore logic when I rebuilt it. Right now, it’s not doing anything, which is why you’re seeing the same behavior whether it’s on or off.
When I first implemented full parallel restore, the hub would send all the commands too quickly, which overwhelmed the mesh network—especially on Z-Wave. It turns out Z-Wave needs a slight pause between commands to stay reliable. So I added a delay to slow it down, and that seemed to fix the issue. Now it’s restoring every device that was flashing more reliably.
One change I’m considering for the next version is to end the flash sequence with all devices turned on, then restore them to their actual previous state afterward. That way, we avoid ending a pattern in the dark—even if the last flash was “off,” it’ll briefly turn “on” before restoring to “off” if that’s how it started.
I just realized a simple thing for the start - turn all lights off, then start the sequence.
Good to know I wasn't crazy when I toggled that setting and nothing happened.
Thanks very nice, I'm not deaf nor am I hard of hearing but when working in the shop this will come in very handy.
Did not install it yet, but a feature I did not see (unless I missed it), would be to flash the selected lights only if they are already on. This way in some places like my shop, if the lights are on, most likely I'm in there and working. If they are off, I'm not there and no need to flash them for nothing. This of course would most likely be only in some situations and other lights still need to flash.
It doesn’t have that specific feature you’re looking for, but it will turn off the lights after flashing if they were originally off—if that helps. The app is designed to restore any switches or lights assigned to flash back to their previous state before the flashing started.
I was thinking more around the lines that if these lights are not on, for sure no one is in that room so don't flash them for nothing.
My family and I usually watch movies together in a dark room for family movie night, so we’re all in there with the lights off—making light flashing really helpful. Sometimes I also leave the lights off when I’m reading a book on my Kindle in dark mode. It’s easier on my eyes, and I can actually read without needing my reading glasses. So yes, having the lights flash even when they’re off definitely has its benefits!
I think I might have not explained it right, what I had in mind is...
If the lights are on, FLASH the lights when an event happens like the doorbell.
If the lights are off, DO NOT FLASH the lights as for sure no one is in that room.
Right, I caught that in your earlier post—where you mentioned that if the lights are off, the room must be empty, so there’s no need to flash them. But in my case, it’s a bit different. We often keep the lights off intentionally while we’re still in the room, like during family movie night or when I’m reading in dark mode.
Also, during the daytime, we don’t use the lights in rooms that get plenty of sunlight through the windows. But even then, we still want to be visually alerted—for example, when the doorbell rings or another important event happens. That’s another reason why we need the lights to flash even when they’re off.
For us, flashing is important no matter the light state. I rely on these visual cues to know when something is happening, and I’m sure there are others in the same boat—people who are using a reading lamp, desk light, or just a screen, with the main lights turned off. So I really think it’s helpful to have flexibility in how the flashing logic works depending on different real-life use cases.
:bell: VisualAlert v1.5.8 Now Available!
Smarter Default Behavior + Toggle Fixes :white_check_mark:
:link: GitHub – TechBill/visualalert
:new: What’s New in v1.5.8
:arrows_counterclockwise: Improved Behavior When Restore Is Disabled
Previously, if Restore Last State was off, devices would just stay on after the alert finished — which was confusing.
Now, when Restore is disabled, all devices will automatically turn off after the alert.
This makes the behavior simpler and more predictable.
:hammer_and_wrench: Toggle Switch Logic Fixed
We updated the logic behind the toggle:
Restore Last State After Alert
(disabled = all devices off after alert)
This toggle had broken in the last update when we reworked restore logic. It’s now fully working again!
:test_tube: Tested & Verified
Tested with 4 switches and 1 RGB bulb:
  • RGB bulb changed color during the alert
  • All devices returned to off (or restored state) as expected
    Everything worked exactly as intended :100:
As always, thanks for your feedback and testing — it’s what keeps making VisualAlert better with every update!
Any chance you could add one more condition to this app. It looks almost perfect for what I'm looking for to help my very hard of hearing Mother In Law stay in her house. I especially like that I can have a different flash duration for different types of events. However, the "restore to previous state" isn't quite what I'm looking for.
I've got a Zen17 on the doorbell to trigger Enbrighten Z-wave switches.
It's day time, so the hallway lights aren't needed, and they're currently off.
The front door bell is rung, and the lights start to flash. MiL comes out of the kitchen and turns the lights off to end the flashing as she's going to the front door. Lights restore to off... not a problem.
It's night time, she's in her bedroom and the hallway lights are off.
The front door bell is rung, and the lights start to flash. MiL gets out of bed and turns the lights ON to end the flashing and so she can see down the hallway as she goes to the front door. Lights restore to off, which is a problem.
Is there a way to address this scenario?
It should be restoring to last state it was in.
If it was off then it will restore to off but if it was on then it restore to on.
Yes, I understand that. I'm wondering if there is a way to make it work for the two scenarios I described, where the action on the switch ends the flashing and sets the new state, and does not simply restore it to it's previous state.
Are you using the one built into my script to stop action?
I use a zwave 4 button remote and one of the button is tied into my stop action script so whenever trigger the visual alert then I don't want wait for the count to end, i use remote button to stop it then it goes back to last state it was in.
No, no extra remotes here, just an 85 year old MiL. I've gotta keep it simple for her.
There’s another option you might find helpful: setting the “off” brightness level on a smart bulb or switches that support it. Instead of turning completely off, the light dims to a low level while flashing. This can be ideal for hallways, acting like a gentle night light while still providing visual alerts—for example, when she’s walking toward the door.
In other rooms, I use a different approach: I pair a Z-Wave or Zigbee bulb with a simple lamp stand, preferably one with an upward dome shade that spreads light evenly. I use the bulb as a visual alert to get my attention when something needs it.
I was born profoundly Deaf and have used sign language all my life, so I understand how difficult it can be to build the perfect visual alert system—one that covers everything important, including a baby monitor for my four kids. It’s not easy, but I made do for years until I discovered the world of home automation. That changed everything. Instead of spending hundreds of dollars on specialized devices that aren’t customizable, I can now build my own solutions.
That’s why I developed VisualAlert. I’ve tried to make it as customizable as possible—because every household is different. If you have ideas for making it better, I’m all ears. I’d love to explore new features and add improvements that help others like us.
I just discovered this App recently - I'm also hearing impaired. I'm wondering if you would consider a new feature - notifications?
If the app could send an event to a dashboard, I could log the doorbell push - even when not at home. I could also event to my Hubitat app on my phone for package arrival. Right now I do both - I've a rule and your app both triggering by the virtual doorbell push connected to my smart doorbell but I'd love to roll it up into one as I'm trying to get off my addiction to rules in HE.
Thanks for your consideration AND this awesome upgrade to 'Light Flasher'.
