I’m seeing an intermittent issue where a contact sensor event is clearly received and logged by the hub, but occasionally does not reach the automation subscribed to it.
Hub: C-8 Pro, currently 2.5.1.181
Sensor: Zooz ZSE41 using Hubitat built-in driver
Device: Garage to House Contact
Action: Turn on Garage LEDs
I originally had this configured as a Simple Automation Rule triggered by contact open. It worked most of the time, but occasionally the device would log the contact-open event and the automation would do nothing.
To eliminate the Simple Automation Rule as the cause, I paused it and recreated the automation from scratch in Rule Machine 5.1:
Trigger: Garage to House Contact contact reports open
Action: On: Garage LEDs
Logging: Events, Triggers, Actions
The same intermittent failure has now occurred with the new RM rule.
A particularly clean example occurred this morning:
08:17:53.864 — device logs Garage to House Contact is open
No Event, Trigger, or Action appears from the RM rule (app:804).
08:19:13.909 — Garage LEDs turned on manually.
I then tested it again:
08:19:53.159 — contact reports open
08:19:53.209 — RM logs Event: Garage to House Contact contact open
08:19:53.211 — RM logs Triggered: Garage to House Contact contact open
08:19:53.268 — RM logs Action: On: Garage LEDs
08:19:53.362 — Garage LEDs turns on.
So when RM receives the event, the entire automation executes essentially immediately. On the failed occurrence, the device event is present in Hubitat but there is no corresponding Event entry from RM at all.
I have now reproduced the same behavior with both Simple Automation Rules and a newly created Rule Machine rule, so it does not appear to be the automation logic or the target switch.
Has anyone seen device events intermittently get recorded by Hubitat but fail to be delivered to subscribed apps/rules on 2.5.1.181? Is there any additional logging or diagnostic information I should capture the next time it occurs?
