I have both an Aeotec V2 (SmartThings) hub and a Hubitat C7 hub (both with internal Z-wave and Zigbee radios, obviously). I'm mostly on HE, but there are a couple devices that work better with SmartThings. It would be convenient to place both hubs in close proximity (~2' apart), but I'm wondering if that would create any interference problems?
(They would both be about 6' from a Unifi Access Point also. That is currently the case for the Hubitat hub and I haven't noticed any obvious interference with Zigbee.)
I have multiple hubs (not just Hubitat) located quite close to one another running Zigbee radios, plus my Wi-Fi / router, and I can't say that I have noticed any issues. The main consideration, as I understand it, would be the channels you choose, making sure they are set appropriately so they do not interfere with each other.
The most common home automation interference issues are around 2.4ghz spectrum, as that is used by your router's 2.4ghz Wi-Fi, Zigbee radios (including Hue hubs, not just Hubitat, SmartThings, Home Assistant, etc.), and Thread. Z-Wave interference is generally not an issue.
I've had Zigbee radios sitting right next to each other w/zero issues. It's more important to keep your various 2.4ghz radios on different channels than your Wi-Fi and each other than it is to physically isolate your hubs from each other. For example:
