Intelligent valve controller
Hello. Mh first post here.
I own a C8 HE and runs smoothly my house. I recently got a water detector and also works fine. So j decided to buh a valve controller to close the water supply if leak is detected. In the local market I found a tuya zigbee intelligent valve controller. And thought I could give it a try. Although it pairs normally, it does not work.
Has anyone tried?
Thank you
Have you got a link to the valve controller you are using so we can see what it looks like?
I got one 5 years ago or so and I have used this driver with it since then: https://raw.githubusercontent.com/markus-li/Hubitat/release/drivers/expanded/zigbee-tuya-valve-expanded.groovy
The valve looks something like this: https://www.aliexpress.com/item/10000055519067.html
I haven’t had a reason to check to see if there have been any built-in drivers released since then that will support my valve, so maybe see if you can find any built-in drivers that work.
@kkossev is a great Tuya drivers developer, he might know.
@lazaridisgeo
Where do you live?
Hi. I'm from Greece.
I cannot post images.. so here is a link of the valve.
(Cannot post links either it seems)
It's MOES Zigbee valve controller, white with blue buttons
I made it work with the driver
"Tuya Zigbee Valve" by kkossev
And works flawlessly
Thank you all
If you join the hub owners group here, you’ll be able to post images and links.
