Integrating w/Lutron & Xfinity
I have the Xfinity security system and saw that I can integrate it with Litton via Lutron's hub. If I got Luton's Pro 2 hub, would I be able to use the HE integration to then also communicate with sensors from the alarm system (I know they are zigbee sensors)? Or is there another way to link HE to the Xfinity alarm system?
Probably not.
With the caveat that I'm not familiar with the details of the Lutron-Xfinity integration, I think it's extremely unlikely it works in such a way that your sensors in the Xfinity system would appear to Hubitat as Lutron devices that could be brought in through Hubitat's Lutron integration. Lutron contact sensors, for example, don't even exist AFAIK.
This probably wouldn't meet your needs, but if your Xfinity system uses Zigbee sensors, you could consider pairing those directly to Hubitat. But they can't remain paired to the Xfinity Zigbee coordinator at the same time, so you would be removing sensors from the Xfinity system in order to use them with Hubitat.
Thanks, I figured that was just wishful thinking on my part especially since I haven't seen anyone talking about integrated with Xfinity. Would have been great though.
Unfortunately you can only control the Lutron Caseta stuff from the Smart Hub Pro. You also can not control the Caseta Lutron motion sensor.
