Good Morning,
I'm a novice HE user -- although I've developed software in a previous life. I use Alexa - but am centralizing all my automations primarily within HE. I want to leverage Alexa's glass break monitor into Safety Monitor. Possible? If so, how?
It’s a back door approach, but the Guard function from Alexa (which includes the Glass Break) can turn on a “light”, if that light was also configured as a virtual motion sensor that was defined to HSM it should give you the desired result. You’d need a virtual driver with both the switch and motion sensor capabilities similar to:
Where is that feature? I see where it can turn something on when Guard is enabled or disabled, but don’t find where it can when it detects something.
Thanks, all,
I'm going to play around with this over the next few weeks. I'll post a note once I have it integrated and let you know how it worked... and how I did it.
I guess I’m talking about something different. Alexa guard lighting randomly turns lights on and off when guard is set to away. But I still don’t see anyway to turn on a light when guard detects something, glass break, etc.
Believe it had both a home similutor and the capability to switch on lights in response to a Guard event at one point. What it does now I couldn’t say, Guard kept picking up my cat and playing its alert and blinking the lights - WAF was nearing floor level so I stopped playing with it…
