Installed latest version rachio integration broken 2.3.0.115 - fixed with 2.3.0.116
lastest update.. suddenly rachio has no devices. double check on my other hub with same login still working fine..
@bravenel
restored previous version and working again..
should i try the upgrade again or do you want to look at logs first.
@bobbyD
confirmed.. reapplied upgrade and broken again..
downgrading again.
come on is anyone going to actualy look at this issue or do i need to open a ticket.
i just tried on my other hub and same issue..
@bobbyD
This is caused by the same issue as Network Setup not working on C-5 hubs, fix is coming shortly.
2.3.0.116 out with a fix.
confirmed fixed! thank you.. sorry to bother you..
