I actually found out my problem might be somewhere else... I am trying to use this "actions" list in multiple pages... So I thought it would be a global thing. But it's not. How can I make it global within my app instance?
Ok, so I finally had some spare time to dive into this state story... But I'm still missing the big picture about multidimensional array's in Groovy. I come from PHP and I can't get this to make sense to me... I have read so many Google pages by now that I'm getting a little tired of Groovy. Can someone please tell me how this language thinks? I'm not the first one trying to store level values of switches per mode right? I've also looked through code of others but even then I can't make any sense of it. This is what I have now what does NOT work, but IMHO shouldn't be soo hard:
input name: "switchChoices", type: "capability.switch", title: "Control these Switches", multiple: true, submitOnChange: true, hideWhenEmpty: true
input name: "switch_by_modes", type: "bool", title: "Use modes for settings?", submitOnChange: true
if (switch_by_modes == true) {
input name: "modeChoices", type: "mode", title: "Which modes do you want to set the lights for?", multiple: true, submitOnChange: true, hideWhenEmpty: true
modeChoices.each { modeName ->
state.levels = [modeName]
paragraph "Mode: <strong>$modeName</strong>", style:"margin-top: 1rem; margin-bottom: -0.5rem;"
switchChoices.each { switchName ->
state.levels["$modeName"] = [switchName]
input name: "levelChoices", type: "number", title: "Light: <strong>$switchName</strong><br>Turn on to level:", hideWhenEmpty: true, style: "padding-left: 2rem;"
state.levels.["$modeName"]["$switchName"] = levelChoices
I did that, but I can't get it to work or the manuals / tutorials I'm running into on Google aren't clear enough for me. And most of them don't say anything about multidimensional.
Exactly, i dont beleive there is any such thing, in groovy you have maps and lists, those are your data structures, maps and json are very similar have a look there has well.
You're going to have to architect your structures around those constraints.
A map is a key value pair, think of the key as being a nameable version of an array index, and it's used the same way.
Yeah. Forget about multidimentional, or arrays in general in terms of how they work in other languages. As even 1 dimentional "array" isn't an "array" in groovy - it is an ArrayList (so back to map and list again...)... And that's an important distinction, too, as an ArrayList can do many things a regular array can not.
Learn map, change your thought process from multidimentional array to map. That is the only way to proceed in groovy or js.
Thank you both for the replies. I have set down and read through the explanations again. But I just don't see how I can save the level values of dimmers per mode. Please enlighten me in how one would do such a thing.
To put it in layman's terms:
day -> light A -> 60
day -> light B -> 50
evening -> light A -> 30
evening -> light B -> 10
So I've tried it again. Still not working. I've tried al sorts of different ways of styles to write this, but I keep getting the same error. Here the last version of code:
And this is what I get. I'm really getting the idea that Groovy isn't really meant to help development improve... It only seems to make it harder (hence the excess of special characters to call a variable)
