Inovelli Red
Anyone able to get the multi tap with these switches working with one of the button controller apps vs rules?
Looking to set up a double tap up for turning in a few lights and a double tap down for turning off the same.
Cheers
Mac
Yes, I've had it working fine. Just make sure you don't disable the on/off delay in the device options. By disabling the delay, you're preventing it from waiting for a second press.
Yep, but took a little figuring out at first.
I made a rule for a Button (not button device), selected the Inovelli switch I wanted, then for button number entered the amount of taps I wanted to use (eg, button 2 for double-tap, 3 for triple-tap, etc). Then the action "pushed" indicates the up paddle, and "held" indicates the down paddle.
Slightly weird but works really well.
fwiw, I am using the driver written by Inovelli (via Hubitat Package Manager). I don't know if all this still applies to the Hubitat native driver.
Thanks. Are you using rules or an app to assign the different states to a specific command ?
Regards.
Mac
Thanks. The press vs hold was confusing in the docs. If I can’t find a user app I’ll set up in rules. Appreciate the help
Mac
Wanting to check if you dont mind.
I'm using the native Inovelli driver from Hubitat.
I don't see auto on/off as an option in the preferences. Are you using the Inovelli driver?
Cheers
Mac
oops - I didn't read your actual question properly, sorry about that.
I used Simple Automation Rules for my setup (not Rule Machine) just because I had it installed already, but Button Controller looks like it would be able to do it, I don't see any obstacles.
The driver from Inovelli themselves has many more options, including this one:
Auto Off Timer Automatically turns the switch off after this many seconds. When the switch is turned on a timer is started that is the duration of this setting. When the timer expires, the switch is turned off. Range: 0..32767 Default: 0
Thanks for the reply. I tried to set up in simple automation...and something is happening but not what i thought i programmed.
I've tried to set up a simple control. But its not reacting the way i would expect
Lookin got achieve:
Double tap up...turn on and set 2 dimmers i have
Double tap down...turn off the 2 dimmers
I have the strangest thing going on.
A double tap up or down dossent do anything...but when i press 1 time down - the 2 dimmers will toggle on, press 1 down again will toggle off
oddly enough...this might work better as there is no way my fan will be left on accidentally BUT would be great to figure out why so i can learn how to use properly
Lastly. I tried to see what was going on in the logs.
Used the following sequence. A few seconds pause between each action (UU is Double Tap Up, DDD is Triple tap down)
On, UU, UUU, UUUU, UUUUU, then pushed that top right scene button
Off, DD, DDD, DDDD, DDDDD
It looks like all of the multi taps up are registered as Pushed Button 1
Looks like all of the multi taps down registered as Pushed Button 2
Hoping someone can point out what i'm doing wrong.
I have a few screen shots below.
  • button assignment for the Inovelli red ( pulled form another thread here so guessing its correct
  • the double tap up simple automation to turn on and set 2 different dimmers.
  • the double tap down simple automation to turn off the dimmers
  • Logs
Logs.
2020-09-05 09:39:35.962 am Fan-Patio is off [physical
2020-09-05 09:39:35.791 am Fan-Patio button 2 was pushed
2020-09-05 09:39:33.710 am Fan-Patio is off [physical]
2020-09-05 09:39:33.635 am Fan-Patio button 2 was pushed
2020-09-05 09:39:27.611 am Fan-Patio is off [physical]
2020-09-05 09:39:27.490 am Fan-Patio button 2 was pushed
2020-09-05 09:39:26.909 am Fan-Patio is off [physical]
2020-09-05 09:39:26.788 am Fan-Patio button 2 was pushed
2020-09-05 09:39:26.208 am Fan-Patio is off [physical]
2020-09-05 09:39:26.113 am Fan-Patio button 2 was pushed
2020-09-05 09:39:25.507 am Fan-Patio is off [physical]
2020-09-05 09:39:25.427 am Fan-Patio button 2 was pushed
2020-09-05 09:39:24.810 am Fan-Patio is off [physical]
2020-09-05 09:39:24.726 am Fan-Patio button 2 was pushed
2020-09-05 09:39:20.011 am Fan-Patio is off [physical]
2020-09-05 09:39:19.892 am Fan-Patio button 2 was pushed
2020-09-05 09:39:19.314 am Fan-Patio is off [physical]
2020-09-05 09:39:19.228 am Fan-Patio button 2 was pushed
2020-09-05 09:39:18.609 am Fan-Patio is off [physical]
2020-09-05 09:39:18.530 am Fan-Patio button 2 was pushed
2020-09-05 09:39:17.811 am Fan-Patio is off [physical]
2020-09-05 09:39:17.730 am Fan-Patio button 2 was pushed
2020-09-05 09:39:12.511 am Fan-Patio is off [physical]
2020-09-05 09:39:12.439 am Fan-Patio button 2 was pushed
2020-09-05 09:39:11.108 am Fan-Patio is off [physical]
2020-09-05 09:39:11.041 am Fan-Patio button 2 was pushed
2020-09-05 09:39:06.512 am Fan-Patio is off [physical]
2020-09-05 09:39:06.428 am Fan-Patio button 2 was pushed
2020-09-05 09:39:05.950 am Fan-Patio is off [physical]
2020-09-05 09:39:05.831 am Fan-Patio button 2 was pushed
2020-09-05 09:39:01.611 am Fan-Patio was turned off [physical]
2020-09-05 09:39:01.529 am Fan-Patio button 2 was pushed
2020-09-05 09:38:56.597 am Fan-Patio button 3 was pushed
2020-09-05 09:38:48.801 am Fan-Patio is on [physical]
2020-09-05 09:38:48.713 am Fan-Patio button 1 was pushed
2020-09-05 09:38:48.002 am Fan-Patio is on [physical]
2020-09-05 09:38:47.926 am Fan-Patio button 1 was pushed
2020-09-05 09:38:47.301 am Fan-Patio is on [physical]
2020-09-05 09:38:47.227 am Fan-Patio button 1 was pushed
2020-09-05 09:38:46.609 am Fan-Patio is on [physical]
2020-09-05 09:38:46.501 am Fan-Patio button 1 was pushed
2020-09-05 09:38:45.905 am Fan-Patio is on [physical]
2020-09-05 09:38:45.837 am Fan-Patio button 1 was pushed
2020-09-05 09:38:40.099 am Fan-Patio is on [physical]
2020-09-05 09:38:40.026 am Fan-Patio button 1 was pushed
2020-09-05 09:38:39.399 am Fan-Patio is on [physical]
2020-09-05 09:38:39.310 am Fan-Patio button 1 was pushed
2020-09-05 09:38:38.597 am Fan-Patio is on [physical]
2020-09-05 09:38:38.523 am Fan-Patio button 1 was pushed
2020-09-05 09:38:38.003 am Fan-Patio is on [physical]
2020-09-05 09:38:37.937 am Fan-Patio button 1 was pushed
2020-09-05 09:38:30.998 am Fan-Patio is on [physical]
2020-09-05 09:38:30.887 am Fan-Patio button 1 was pushed
2020-09-05 09:38:30.298 am Fan-Patio is on [physical]
2020-09-05 09:38:30.182 am Fan-Patio button 1 was pushed
2020-09-05 09:38:29.698 am Fan-Patio is on [physical]
2020-09-05 09:38:29.629 am Fan-Patio button 1 was pushed
2020-09-05 09:38:23.201 am Fan-Patio is on [physical]
2020-09-05 09:38:23.144 am Fan-Patio button 1 was pushed
2020-09-05 09:38:22.596 am Fan-Patio is on [physical]
2020-09-05 09:38:22.514 am Fan-Patio button 1 was pushed
2020-09-05 09:38:15.424 am Fan-Patio was turned on [physical]
2020-09-05 09:38:15.356 am Fan-Patio button 1 was pushed
First thing I would suggest is disable "Toggle on/off".
I found that one shortly after i posted. Still doesnt work on a double tap.
Now a single tap down will turn on....a single hold down turns off.
I'm installing the Inovelli drivers to see if that fixes the issue.
Cheers
OK. I downloaded the Inovelli drivers.
Works as expected now. UU - lights turn on. DD lights turn off.
And in the logs i can see all of he button presses.
Now to move onto the RGB status feedback!
Appreciate your suggestions.
Odd that the Hubitat drivers do not work!
Mac
