Inovelli Red Switches
Hi,
I have successfully added my switch to my hub. The issue comes when trying to make paramater changes. In device settings I have a bunch of boxes, config, double tap, flash, hold, on, off, refresh etc. I have no clue how to make changes and which one I am supposed to be changing. I want to change it to off and on immediate rather than ramping up and down as well and just have no clue how to do this.
A good thread to peek at:
The key here is that you need to load the updated Inovelli driver to replace the old one that is built-in to Hubitat
Get the latest Device Drivers from here: https://support.inovelli.com/portal/en/kb/articles/hubitat-device-drivers
If you use Hubitat Package Managaer (HPM) to install the Inovelli drivers then it will assist with keeping it updated when new version of the driver get released.
If you don't have a preference area like this then you're most likely using the hubitat stock driver
you say red switch in your title but I'll assume your talking about dimmers since your referencing ramp rates.
this is the driver you need.
red series Dimmer
I have added the driver but things still look the same. What step am I missing.
I added the driver but things look the same. Is there another step in the process
Did you change the driver in the device details for the switch?
After you change the driver, you have to hit the "Configure" button for it to be official.
