it seems slow to respond (from the switch directy also) also when i dim it it maybe goes down like 5% ???
I have the inovelli driver installed. any idea?
fan is 10 feet from the outlet and it is wired properly with H and N wires at the switch, and H,N,F,L at the fan unit (thank goodness my fan wire had lables on them !!)
I just installed my first 2 this past weekend. I believe this is because it's technically a scene controller so when you push a button, it has to make sure you are not double, triple, quadruple.... tapping before it does its business. I think it allows up to 6 presses.
Are you using the light control with smart bulbs (e.g. Local protection settings for Light is enabled)? If this is the case, then I agree it's very slow to respond.
If you're using it to control the bulbs in the fan directly, then I didn't have the same experience and found it to control them without delay.
1 .Pull the air gap at the bottom of the LZW36 to cut power to it for 30 seconds.
2. Exclude the switch.
3. Pull the power again for 30 seconds.
3 Include manually, don't use SmartStart. Leave all the security unchecked.
