Inovelli Driver Install Failure - Fatal Error
I have a C-8 Pro running 2.4.0.144. While attempting to save an edit to the Inovelli driver as a workaround to not being able to save preferences in inovelli devices described here (New UI (2.4.0.144) - Unable to save Preferences for Inovelli devices) I encountered the error "Column "ZW_DEVICE_CLASS" not found; SQL statement". I have attempted a reboot of the hub with the "Rebuild database on reboot" checked with no luck. I even excluded and deleted my inovelli devices and deleted the driver via HPM to try to fix the issue, but it seems it is worse now as I get the error below while trying to reinstall the Inovelli Drivers (Gen 2) driver. In the HPM logs, I don't see much about the error other than the entry "Fatal error occurred, rolling back". I do not see the driver entry in HPM to uninstall or a driver entry to remove while checking the drivers code page.
"Error Occurred During Installation
An error occurred while installing the package: Failed to install driver https://raw.githubusercontent.com/InovelliUSA/Hubitat/master/Drivers/inovelli-dimmer-red-series-lzw31-sn.src/inovelli-dimmer-red-series-lzw31-sn.groovy. Please notify the package developer.. Be sure the package is not in use with devices."
Just an update. I tried restoring my oldest backups and still had the issue so it may have been there for a while. Since I was unable to figure it out, I did a soft reset and redid my setup and I can edit the drivers with no issues now but with the new Hubitat update, it fixed the original inovelli edit issue so editing the drivers is a moot point now.
