I have a bunch of Inovelli Red Dimmers and a C7 hub. I'm running firmware 1.48 because I couldn't get the firmware to update on the 2nd switch I tried to updat, so stopped trying to do the others (but that's a different story). My C7 is running 2.3.0.113.
For the past few weeks, all of a sudden, I will turn on a light and then, after a bit, it will dim down and turn off. Sometimes it will come back on, but usually not.
For the ones I've associated I have these settings:
Master
1 (dimming), 0
2 (dimming at switch), 3
3 (ramp), 0
4 (ramp at switch) 0
9 (default level when powered on from switch), 99
10 (default level when powered on from Z-Wave), 99
11 (State after power restored), 100
12 (Association behavior) blank (i.e. default of 15)
Slave:
Master
1 (dimming), 3
3 (ramp), 0
For Param 12 (Association behavior) I have 1 pair with 12 set to 11 on the Master, on another pair I have 12 to 11 on the Slave and on my 3rd pair I have 12 set to 11 on both. I'm doing that to experiment as I found a post on the Inovelli site that said "You can have multiple destination devices in each association setup. If you have any associations that go both ways, make sure you change the “Association Behavior” parameter on one of them to 11"
Does that matter for the pairs?
Any idea why it is happening on red dimmers not in a 3-way (i.e. no association)? (While not in a 3-way they do have rules that say 1 push = 100 and a 1 held = 0 as I set the config button, #7, to a dim value, say about 30%, and want it to go to 100% when 1 pushed, even if on)
