Innr sp222 plug erratic
I have a basic rule set up for a device to turn on and off several times in a day, for some reason it is not turning off between 07.00am and 0730am. Have tried different times but still wont turn off about this time. Have even tried starting rule at different times but no joy. I am turning the device on using a Time of day and then using a wait command before turning off, did try turning on and off with time of da but still no joy.
I am using a innr sp222 plug with the generic zigbe outlet driver, anyone else had a similar problem or is there a better driver.
TIA User 437
Can you turn it on and off via the device page?
Yes, it turns on OK, but not always turning off, gonna try another plug to see if it is maybe a faulty plug
Also move it closer to the hub to see if that helps. (could be you don't have enough repeaters in your mesh)
Will add another plug as a repeater, and see what happens
Someone else on here said these seem to be weak repeaters.
