Innr SP 242 not turning off and permanently on
@Gerry-Innr,
I hope you can help or advise on the below.
Four of my Innr SP 242 plug sockets have been working great and not had any issues.
However, recently one of my Innr Sp 242 plug just stopped responding to the off switch and command.
Both the software and LED button is working as expected, i.e. LED light turns off and software is showing correct status, however, the plug will not turn off physically and any connected device will remain on and power consumption is reading is accurate and updates even in software off state.
Device data:
• endpointId: 01
• application: 17
• driver: 2.0.0 2023/04/29 11:26 PM
• firmwareMT: 1166-0332-17173685
• inClusters: 0000,0003,0004,0005,0006,0008,1000,0702,0B04,E001
• manufacturer: innr
• model: SP 242
• outClusters: 000A,0019
• powerCluster: 0B04
• softwareBuild: 1.7.23
I do not currently have any devices connected to the plug, but as you can see from the log below that the device is still reporting a small power although it is supposed to be in off state.
Events log
Any help would be appreciated.
Just adding another data point.
I have a number of these in my house, including one under my desk right now.
Just checked and its working as expected.
I'm on 2.3.9.196 C8 Pro
Using the "Tuya Zigbee Metering Plug" driver 1.9.3
I'm not great at reading logs, but here they if they help
Summary
Hi @iEnam that sounds like the relay is defective, i.e. its contacts welded together. That can happen when the "inrush current" drawn by the connected appliance at switch-on is too high for too long, or when an "inductive load" is switched off causing a voltage peak. Repeated such occurrences can weld the contacts together. Shouldn't happen normally but if your appliance is old and draws a lot of current...
Best contact our service dept. for a replacement.
Thanks for your reply.
Not sure if the device is defective as I have experienced similar issue in the past with other plugs, but as you explain the issue is most likely due to an overload.
I have reset/re-paired the socket and it is functioning as expected again!
I have experienced a similar issue with this extension setup using a Tasmota plug socket previously as well.
I am using the below 5 gang extension socket box to power a laptop, monitor and mobile phone and Bluetooth speakers.
5 Gang extension socket
(Hulker 3M Extension Lead with USB, Cable Management Box 5 Gang Plug Extension Socket with Switch, 5 Way Power Strip Cable Tidy Box, Desk Cords Organizer for Kitchen, Dorm, Office, Home: Amazon.co.uk: DIY & Tools)
As it is working again and I have experienced similar issue with another socket in the past, is there something the manufacturer can do to improve the overload issue?
Note that all the sockets that stopped responding to off function in the past are all still working!
Thanks again.
Logs
dev:42222024-10-23 07:26:28.115 PMinfoDehumidifier 2 amperage is 0 A (refresh)
dev:42222024-10-23 07:26:28.092 PMinfoDehumidifier 2 voltage is 245 V (refresh)
dev:42222024-10-23 07:26:28.074 PMinfoDehumidifier 2 power is 0 W (refresh)
dev:42222024-10-23 07:26:28.048 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D2010B04240B0529000005050021F500080500210000, dni:10D2, endpoint:01, cluster:0B04, size:24, attrId:050B, encoding:29, command:01, value:0000, clusterInt:2820, attrInt:1291, additionalAttrs:[[value:00F5, encoding:21, attrId:0505, consumedBytes:5, attrInt:1285], [value:0000, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288]]]
dev:42222024-10-23 07:26:28.044 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D2010B04240B0529000005050021F500080500210000, dni: 10D2, endpoint: 01, cluster: 0B04, size: 24, attrId: 050B, encoding: 29, command: 01, value: 000005050021F500080500210000
dev:42222024-10-23 07:26:27.994 PMdebugDehumidifier 2 pollPower()..
dev:42222024-10-23 07:26:23.985 PMinfoDehumidifier 2 power is 44 W
dev:42222024-10-23 07:26:23.984 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D2010B040A0B05292C00, dni:10D2, endpoint:01, cluster:0B04, size:0A, attrId:050B, encoding:29, command:0A, value:002C, clusterInt:2820, attrInt:1291]
dev:42222024-10-23 07:26:23.981 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D2010B040A0B05292C00, dni: 10D2, endpoint: 01, cluster: 0B04, size: 0A, attrId: 050B, encoding: 29, command: 0A, value: 2C00
dev:42222024-10-23 07:26:22.083 PMdebugDehumidifier 2 Ignored duplicated switch event for model SP 242
dev:42222024-10-23 07:26:22.082 PMdebugDehumidifier 2 Event enter: [name:switch, value:off]
dev:42222024-10-23 07:26:22.079 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D20100060800001000, dni: 10D2, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00
dev:42222024-10-23 07:26:22.015 PMinfoDehumidifier 2 Dehumidifier 2 Dehumidifier 2 was turned off [digital]
dev:42222024-10-23 07:26:21.984 PMdebugDehumidifier 2 Switch state changed from on to off
dev:42222024-10-23 07:26:21.983 PMdebugDehumidifier 2 Event enter: [name:switch, value:off]
dev:42222024-10-23 07:26:21.982 PMdebugDehumidifier 2 parse: description is catchall: 0104 0006 01 01 0040 00 10D2 00 00 0000 0B 01 0000
dev:42222024-10-23 07:26:21.909 PMdebugDehumidifier 2 off() sending [he cmd 0x10D2 0x01 6 0 {}, delay 2000]
dev:42222024-10-23 07:26:21.897 PMdebugDehumidifier 2 Switching Dehumidifier 2 Off
dev:42222024-10-23 07:26:18.969 PMinfoDehumidifier 2 voltage is 242 V
dev:42222024-10-23 07:26:18.967 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D2010B040A050521F200, dni:10D2, endpoint:01, cluster:0B04, size:0A, attrId:0505, encoding:21, command:0A, value:00F2, clusterInt:2820, attrInt:1285]
dev:42222024-10-23 07:26:18.965 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D2010B040A050521F200, dni: 10D2, endpoint: 01, cluster: 0B04, size: 0A, attrId: 0505, encoding: 21, command: 0A, value: F200
dev:42222024-10-23 07:26:00.239 PMdebugDehumidifier 2 ignored amperage 1.324 A (change from 1.311 is less than 25 mA)
dev:42222024-10-23 07:26:00.237 PMdebugDehumidifier 2 Dehumidifier 2 ignored voltage 243 V (change from 243 is less than 1 V)
dev:42222024-10-23 07:26:00.219 PMinfoDehumidifier 2 power is 163 W
dev:42222024-10-23 07:26:00.217 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D2010B04240B0529A30005050021F300080500212C05, dni:10D2, endpoint:01, cluster:0B04, size:24, attrId:050B, encoding:29, command:01, value:00A3, clusterInt:2820, attrInt:1291, additionalAttrs:[[value:00F3, encoding:21, attrId:0505, consumedBytes:5, attrInt:1285], [value:052C, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288]]]
dev:42222024-10-23 07:26:00.213 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D2010B04240B0529A30005050021F300080500212C05, dni: 10D2, endpoint: 01, cluster: 0B04, size: 24, attrId: 050B, encoding: 29, command: 01, value: A30005050021F300080500212C05
dev:42222024-10-23 07:26:00.111 PMtraceDehumidifier 2 sendZigbeeCommands : [he raw 0x10D2 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200]
dev:42222024-10-23 07:26:00.096 PMdebugDehumidifier 2 polling all 0x0B04 attributes
dev:42222024-10-23 07:26:00.096 PMdebugDehumidifier 2 polling.. refreshAll is false
dev:42222024-10-23 07:26:00.094 PMdebugDehumidifier 2 autoPoll()
dev:42222024-10-23 07:25:12.369 PMdebugDehumidifier 2 attribute report: cluster=0000 attrId=FFE4 value=00 status=null data=null
dev:42222024-10-23 07:25:12.368 PMdebugDehumidifier 2 attribute report: cluster=0000 attrId=0001 value=17 status=null data=null
dev:42222024-10-23 07:25:12.367 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D20100001001002017E4FF2000, dni:10D2, endpoint:01, cluster:0000, size:10, attrId:0001, encoding:20, command:0A, value:17, clusterInt:0, attrInt:1, additionalAttrs:[[value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:42222024-10-23 07:25:12.365 PMdebugDehumidifier 2 Cluster 0000 Tuya specific attrId FFE4 value 00)
dev:42222024-10-23 07:25:12.362 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D20100001001002017E4FF2000, dni: 10D2, endpoint: 01, cluster: 0000, size: 10, attrId: 0001, encoding: 20, command: 0A, value: 17E4FF2000
dev:42222024-10-23 07:25:00.529 PMdebugDehumidifier 2 ignored amperage 1.318 A (change from 1.311 is less than 25 mA)
dev:42222024-10-23 07:25:00.484 PMinfoDehumidifier 2 voltage is 243 V
dev:42222024-10-23 07:25:00.363 PMinfoDehumidifier 2 power is 162 W
dev:42222024-10-23 07:25:00.357 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D2010B04240B0529A20005050021F300080500212605, dni:10D2, endpoint:01, cluster:0B04, size:24, attrId:050B, encoding:29, command:01, value:00A2, clusterInt:2820, attrInt:1291, additionalAttrs:[[value:00F3, encoding:21, attrId:0505, consumedBytes:5, attrInt:1285], [value:0526, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288]]]
dev:42222024-10-23 07:25:00.352 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D2010B04240B0529A20005050021F300080500212605, dni: 10D2, endpoint: 01, cluster: 0B04, size: 24, attrId: 050B, encoding: 29, command: 01, value: A20005050021F300080500212605
dev:42222024-10-23 07:25:00.248 PMtraceDehumidifier 2 sendZigbeeCommands : [he raw 0x10D2 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200]
dev:42222024-10-23 07:25:00.224 PMdebugDehumidifier 2 polling all 0x0B04 attributes
dev:42222024-10-23 07:25:00.222 PMdebugDehumidifier 2 polling.. refreshAll is false
dev:42222024-10-23 07:25:00.221 PMdebugDehumidifier 2 autoPoll()
dev:42222024-10-23 07:24:33.968 PMinfoDehumidifier 2 power is 163 W
dev:42222024-10-23 07:24:33.966 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D2010B040A0B0529A300, dni:10D2, endpoint:01, cluster:0B04, size:0A, attrId:050B, encoding:29, command:0A, value:00A3, clusterInt:2820, attrInt:1291]
dev:42222024-10-23 07:24:33.964 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D2010B040A0B0529A300, dni: 10D2, endpoint: 01, cluster: 0B04, size: 0A, attrId: 050B, encoding: 29, command: 0A, value: A300
dev:42222024-10-23 07:24:00.280 PMdebugDehumidifier 2 ignored amperage 1.318 A (change from 1.311 is less than 25 mA)
dev:42222024-10-23 07:24:00.279 PMdebugDehumidifier 2 Dehumidifier 2 ignored voltage 244 V (change from 244 is less than 1 V)
dev:42222024-10-23 07:24:00.252 PMinfoDehumidifier 2 power is 160 W
dev:42222024-10-23 07:24:00.250 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D2010B04240B0529A00005050021F400080500212605, dni:10D2, endpoint:01, cluster:0B04, size:24, attrId:050B, encoding:29, command:01, value:00A0, clusterInt:2820, attrInt:1291, additionalAttrs:[[value:00F4, encoding:21, attrId:0505, consumedBytes:5, attrInt:1285], [value:0526, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288]]]
dev:42222024-10-23 07:24:00.243 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D2010B04240B0529A00005050021F400080500212605, dni: 10D2, endpoint: 01, cluster: 0B04, size: 24, attrId: 050B, encoding: 29, command: 01, value: A00005050021F400080500212605
dev:42222024-10-23 07:24:00.199 PMtraceDehumidifier 2 sendZigbeeCommands : [he raw 0x10D2 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200]
dev:42222024-10-23 07:24:00.153 PMdebugDehumidifier 2 polling all 0x0B04 attributes
dev:42222024-10-23 07:24:00.152 PMdebugDehumidifier 2 polling.. refreshAll is false
dev:42222024-10-23 07:24:00.150 PMdebugDehumidifier 2 autoPoll()
dev:42222024-10-23 07:23:51.967 PMinfoDehumidifier 2 power is 161 W
dev:42222024-10-23 07:23:51.965 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D2010B040A0B0529A100, dni:10D2, endpoint:01, cluster:0B04, size:0A, attrId:050B, encoding:29, command:0A, value:00A1, clusterInt:2820, attrInt:1291]
dev:42222024-10-23 07:23:51.963 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D2010B040A0B0529A100, dni: 10D2, endpoint: 01, cluster: 0B04, size: 0A, attrId: 050B, encoding: 29, command: 0A, value: A100
dev:42222024-10-23 07:23:43.968 PMinfoDehumidifier 2 amperage is 1.311 A
dev:42222024-10-23 07:23:43.966 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D2010B040A0805211F05, dni:10D2, endpoint:01, cluster:0B04, size:0A, attrId:0508, encoding:21, command:0A, value:051F, clusterInt:2820, attrInt:1288]
dev:42222024-10-23 07:23:43.964 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D2010B040A0805211F05, dni: 10D2, endpoint: 01, cluster: 0B04, size: 0A, attrId: 0508, encoding: 21, command: 0A, value: 1F05
dev:42222024-10-23 07:23:33.019 PMinfoDehumidifier 2 energy is 0.02 kWh, energyCost=$3.81 (rate=$0.21326), duration=5.43 Days
dev:42222024-10-23 07:23:32.973 PMdebugDehumidifier 2 energy_total=0.02, state.lastResetEnergy=0.0
dev:42222024-10-23 07:23:32.972 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D201070212000025020000000000, dni:10D2, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000000002, clusterInt:1794, attrInt:0]
dev:42222024-10-23 07:23:32.969 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D201070212000025020000000000, dni: 10D2, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 020000000000
dev:42222024-10-23 07:23:13.972 PMinfoDehumidifier 2 power is 159 W
dev:42222024-10-23 07:23:13.970 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D2010B040A0B05299F00, dni:10D2, endpoint:01, cluster:0B04, size:0A, attrId:050B, encoding:29, command:0A, value:009F, clusterInt:2820, attrInt:1291]
dev:42222024-10-23 07:23:13.968 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D2010B040A0B05299F00, dni: 10D2, endpoint: 01, cluster: 0B04, size: 0A, attrId: 050B, encoding: 29, command: 0A, value: 9F00
dev:42222024-10-23 07:23:00.181 PMdebugDehumidifier 2 ignored amperage 1.33 A (change from 1.349 is less than 25 mA)
dev:42222024-10-23 07:23:00.180 PMdebugDehumidifier 2 Dehumidifier 2 ignored voltage 244 V (change from 244 is less than 1 V)
dev:42222024-10-23 07:23:00.178 PMdebugDehumidifier 2 ignored power 157 W (change from 157 is less than 1 W)
dev:42222024-10-23 07:23:00.176 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D2010B04240B05299D0005050021F400080500213205, dni:10D2, endpoint:01, cluster:0B04, size:24, attrId:050B, encoding:29, command:01, value:009D, clusterInt:2820, attrInt:1291, additionalAttrs:[[value:00F4, encoding:21, attrId:0505, consumedBytes:5, attrInt:1285], [value:0532, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288]]]
dev:42222024-10-23 07:23:00.172 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D2010B04240B05299D0005050021F400080500213205, dni: 10D2, endpoint: 01, cluster: 0B04, size: 24, attrId: 050B, encoding: 29, command: 01, value: 9D0005050021F400080500213205
dev:42222024-10-23 07:23:00.116 PMtraceDehumidifier 2 sendZigbeeCommands : [he raw 0x10D2 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200]
dev:42222024-10-23 07:23:00.097 PMdebugDehumidifier 2 polling all 0x0B04 attributes
dev:42222024-10-23 07:23:00.096 PMdebugDehumidifier 2 polling.. refreshAll is false
dev:42222024-10-23 07:23:00.095 PMdebugDehumidifier 2 autoPoll()
dev:42222024-10-23 07:22:43.967 PMinfoDehumidifier 2 power is 157 W
dev:42222024-10-23 07:22:43.965 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D2010B040A0B05299D00, dni:10D2, endpoint:01, cluster:0B04, size:0A, attrId:050B, encoding:29, command:0A, value:009D, clusterInt:2820, attrInt:1291]
dev:42222024-10-23 07:22:43.962 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D2010B040A0B05299D00, dni: 10D2, endpoint: 01, cluster: 0B04, size: 0A, attrId: 050B, encoding: 29, command: 0A, value: 9D00
dev:42222024-10-23 07:22:34.126 PMdebugDehumidifier 2 attribute report: cluster=0000 attrId=FFE4 value=00 status=null data=null
dev:42222024-10-23 07:22:34.126 PMdebugDehumidifier 2 attribute report: cluster=0000 attrId=0001 value=17 status=null data=null
dev:42222024-10-23 07:22:34.124 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D20100001001002017E4FF2000, dni:10D2, endpoint:01, cluster:0000, size:10, attrId:0001, encoding:20, command:0A, value:17, clusterInt:0, attrInt:1, additionalAttrs:[[value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:42222024-10-23 07:22:34.122 PMdebugDehumidifier 2 Cluster 0000 Tuya specific attrId FFE4 value 00)
dev:42222024-10-23 07:22:34.120 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D20100001001002017E4FF2000, dni: 10D2, endpoint: 01, cluster: 0000, size: 10, attrId: 0001, encoding: 20, command: 0A, value: 17E4FF2000
dev:42222024-10-23 07:22:30.970 PMinfoDehumidifier 2 voltage is 244 V
dev:42222024-10-23 07:22:30.968 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D2010B040A050521F400, dni:10D2, endpoint:01, cluster:0B04, size:0A, attrId:0505, encoding:21, command:0A, value:00F4, clusterInt:2820, attrInt:1285]
dev:42222024-10-23 07:22:30.966 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D2010B040A050521F400, dni: 10D2, endpoint: 01, cluster: 0B04, size: 0A, attrId: 0505, encoding: 21, command: 0A, value: F400
dev:42222024-10-23 07:22:13.966 PMinfoDehumidifier 2 power is 155 W
dev:42222024-10-23 07:22:13.964 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D2010B040A0B05299B00, dni:10D2, endpoint:01, cluster:0B04, size:0A, attrId:050B, encoding:29, command:0A, value:009B, clusterInt:2820, attrInt:1291]
dev:42222024-10-23 07:22:13.962 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D2010B040A0B05299B00, dni: 10D2, endpoint: 01, cluster: 0B04, size: 0A, attrId: 050B, encoding: 29, command: 0A, value: 9B00
dev:42222024-10-23 07:22:00.293 PMdebugDehumidifier 2 ignored amperage 1.343 A (change from 1.349 is less than 25 mA)
dev:42222024-10-23 07:22:00.291 PMdebugDehumidifier 2 Dehumidifier 2 ignored voltage 245 V (change from 245 is less than 1 V)
dev:42222024-10-23 07:22:00.280 PMinfoDehumidifier 2 power is 153 W
dev:42222024-10-23 07:22:00.278 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D2010B04240B0529990005050021F500080500213F05, dni:10D2, endpoint:01, cluster:0B04, size:24, attrId:050B, encoding:29, command:01, value:0099, clusterInt:2820, attrInt:1291, additionalAttrs:[[value:00F5, encoding:21, attrId:0505, consumedBytes:5, attrInt:1285], [value:053F, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288]]]
dev:42222024-10-23 07:22:00.274 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D2010B04240B0529990005050021F500080500213F05, dni: 10D2, endpoint: 01, cluster: 0B04, size: 24, attrId: 050B, encoding: 29, command: 01, value: 990005050021F500080500213F05
dev:42222024-10-23 07:22:00.112 PMtraceDehumidifier 2 sendZigbeeCommands : [he raw 0x10D2 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200]
dev:42222024-10-23 07:22:00.090 PMdebugDehumidifier 2 polling all 0x0B04 attributes
dev:42222024-10-23 07:22:00.089 PMdebugDehumidifier 2 polling.. refreshAll is false
dev:42222024-10-23 07:22:00.088 PMdebugDehumidifier 2 autoPoll()
dev:42222024-10-23 07:21:47.911 PMinfoDehumidifier 2 amperage is 1.349 A (refresh)
dev:42222024-10-23 07:21:47.858 PMinfoDehumidifier 2 voltage is 245 V (refresh)
dev:42222024-10-23 07:21:47.839 PMinfoDehumidifier 2 power is 151 W (refresh)
dev:42222024-10-23 07:21:47.837 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D2010B04240B0529970005050021F500080500214505, dni:10D2, endpoint:01, cluster:0B04, size:24, attrId:050B, encoding:29, command:01, value:0097, clusterInt:2820, attrInt:1291, additionalAttrs:[[value:00F5, encoding:21, attrId:0505, consumedBytes:5, attrInt:1285], [value:0545, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288]]]
dev:42222024-10-23 07:21:47.833 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D2010B04240B0529970005050021F500080500214505, dni: 10D2, endpoint: 01, cluster: 0B04, size: 24, attrId: 050B, encoding: 29, command: 01, value: 970005050021F500080500214505
dev:42222024-10-23 07:21:47.784 PMdebugDehumidifier 2 pollPower()..
dev:42222024-10-23 07:21:43.954 PMinfoDehumidifier 2 power is 243 W
dev:42222024-10-23 07:21:43.952 PMdebugDehumidifier 2 parse: Desc Map: [raw:10D2010B040A0B0529F300, dni:10D2, endpoint:01, cluster:0B04, size:0A, attrId:050B, encoding:29, command:0A, value:00F3, clusterInt:2820, attrInt:1291]
dev:42222024-10-23 07:21:43.950 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D2010B040A0B0529F300, dni: 10D2, endpoint: 01, cluster: 0B04, size: 0A, attrId: 050B, encoding: 29, command: 0A, value: F300
dev:42222024-10-23 07:21:41.824 PMinfoDehumidifier 2 Dehumidifier 2 Dehumidifier 2 was turned on [physical]
dev:42222024-10-23 07:21:41.774 PMdebugDehumidifier 2 Switch state changed from off to on
dev:42222024-10-23 07:21:41.773 PMdebugDehumidifier 2 Event enter: [name:switch, value:on]
dev:42222024-10-23 07:21:41.771 PMdebugDehumidifier 2 parse: description is read attr - raw: 10D20100060800001001, dni: 10D2, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01
Good that it's working again. Not sure what happened then and don't know about that 5 gang extension socket. It's not an overload; the plug would switch OFF then.
We've had no other notifications that a plug was permanently on but started functioning again after a factory reset... Did a simple unplug / replug not solve the issue? Did you also try to unplug the SP 242, plug it into a wall socket without extension socket in between, and then try the button?
Unfortunately, a simple unplug/re-plug did not solve the issue.
I've tried it with other devices and without an extension socket in between yesterday - the socket was still permanently on.
I did a simple reset today by holding the power button for 10 seconds and it started working again straight away.
(EDIT: was testing with the dehumidifier again today with the SP242 plugged into one of the gang of a normal extension cable with 5 gangs. Note with my original setup, I had the SP242 powering the whole of the 5 gang box extension socket to monitor all load on the extension).
Worst thing is these extension sockets must be cursed as I had it happen to me a few times with other sockets in the past, including AJAX and Tasmota sockets.
I am using the same hub and driver.
This issue is probably more specific to my environment/setup, plug working again after a reset.
I wonder if there's a market for a plug which has the "hardening" (beefier contacts, fast fuse, or breaker) to thwart the melt-down. Folk might pay a bit more for a plug for which could be safely used on equipment that "pushes the threshold" of your standard plug. I'm talking something slightly above the 15amp norm but not all the way up to a 30amp rating.
Or is it the case that that inrush is just really hard to accommodate/deal with?
Of course a tripped breaker or burned fuse would be a hassle if this surge was an every day situation.
Hi @PunchCardPgmr since iEnam's plug is working again after a factory reset, it's not the relay contacts that welded together. The SP 24x plugs all three have the same relay rated for 250V and 16A continuous current, and it's "TV-8 rated" which means it can withstand inrush currents up to 128A and 10000 cycles of making and breaking its rated loads (voltage and current), without the contacts eroding enough to weld together. You won't easily find a smart plug with a better relay :wink:
