It seems as if the indicator capability is not available or has been renamed. I am porting an app I wrote over from SmartThings and the preference selection shows up as empty.
input name: "switches_on", title: "Turn on indicators on switches...", type: "capability.indicator", multiple: true, required: false
Mike, I don’t want to remove it, I need to control the indicators in this app. It’s used to kill them in bedrooms at night time. Can I send the raw commands from an app in Hubitat instead?
Finally got back to looking at this, however there are no device commands available for controlling the indicator LED's. They exist in the preference panel.
You're the only person that's requested this, so we can look at it. It was dropped over here as there isn't a direct zigbee equal. I'll bring it up in engineering and see what the take is.
I would be happy to have the Generic Z-Wave Smart Dimmer (& Switch) and the GE Smart Fan Control drivers updated. Those three represent the devices in use in our bedroom where I change the indicators at night.
@srwhite did you get anywhere with this? I used your app over on ST and I wondered if it would port over since it's such a simple app. As you mention the capability.indicator doesn't seem to be available. What did you end up doing?
