Inclusion, Exclusion, and Factory Reset procedures
Feel free to add to the list. Once you know these, migration is an absolute breeze.
First, a relatively quick way to include/exclude
Z-Wave devices from your hub is to use an Aeon Minimote, Z-Stick, or similar device.
Using an Aeon Minimote for exclusion:
Exclusion:
  1. Put Minimote as close as possible to the device
  2. Press "-", or "Remove", depending on which version you have
  3. The Minimote will blink red
  4. Perform the exclusion procedure for your specific device
  5. The Minimote will light solid blue for a few seconds, and then continue blinking red
  6. You can now stop, or continue to exclude more devices. Wait for the red light to stop blinking before inclusion.
I didn't have luck with the Minimote's Inclusion Mode with HE, but it will also manually with the inclusion procedures below as long as it's not too far away from the hub or a repeating node. *See JDRoberts addition below this post.
You can also do this for Z-Wave devices with an Aeon Z-Stick:
Inclusion:
  1. To initiate Inclusion-Mode, unplug the Z-Stick from the USB connector and then tap the
    button. (The LED will blink slowly.)
    Note: While in Inclusion-Mode, the Z-Stick is in perpetual add/inclusion. There is no
    need to press the button on the Z-Stick again to include each new device.
  2. To include a new Z-Wave device into the network, simply go to the device with the ZStick
    and press the button on the device you wish to include. (The LED on the Z-Stick
    will blink fast during a network neighbor discovery and stay solid for 3 seconds to
    indicate successful inclusion of the device into the network.)
  3. The LED will then return to blinking slowly, indicating readiness for further device
    inclusions. Repeat step 2 for each device as you wish to include.
  4. Tap the Z-Stick button to turn it off.
Exclusion-Mode : Deleting/Removing/Excluding Z-Wave Devices from the Z-Wave Network
  1. To initiate Removal-Mode, unplug the Z-Stick from the USB connector. Then press and
    hold down the button for approximately 3 seconds. (The LED will transition from
    blinking slowly to blinking fast.)
    Note: While in Removal-Mode, the Z-Stick is in perpetual removal/exclusion where it
    will remove Z-Wave devices from the networks they are currently paired to. There is no
    need to press the button on the Z-Stick again to exclude each device.
  2. To remove a Z-Wave device from the network, simply go to the device with the Z-Stick
    and press the button on the device you wish to remove. (The LED on the Z-Stick will
    immediately stay solid for 3 seconds to indicate successful removal from the network.)
  3. The LED will then return to blinking fast, indicating readiness for further device
    exclusions. Repeat step 2 for each device as you wish to exclude.
  4. Tap the Z-Stick button to turn off.
Manual Inclusion/Exclusion/Reset Procedures
Monoprice Motion & Temperature Sensor
(15271)
Exclusion:
  1. Put hub into exclusion mode
  2. Press the program button on the rear of the sensor with a paperclip for 1-second and release.
Inclusion:
  1. Put hub into inclusion mode
Ecolink Motion Sensor
Both (PIRZWAVE2-ECO) and (PIRZWAVE2.5-ECO)
Exclusion:
  1. Remove cover
  2. Remove battery
  3. Put hub into exclusion mode
  4. Wait 5 seconds and re-insert battery
Inclusion:
  1. Remove cover
  2. Remove battery
  3. Put hub into inclusion mode
Iris Motion Sensor
(3326-L)
Exclusion:
  1. Just delete device from hub IDE
Factory Reset:
  1. Remove battery
  2. Hold down reset button while re-inserting battery
  3. Device will blink red to signify it is being reset
Inclusion:
  1. Remove battery
  2. Put hub into inclusion mode
  3. Insert battery
GE Zigbee Switch and Dimmer
(45856 and 45857)
Factory reset:
  1. Lift/pull out the air gap switch at the bottom left of the rocker
  2. Hold down the on/up button and push in the air gap switch
  3. Within 4 seconds, release the on/up button
  4. The LED will blink to indicate the device is reset and ready to pair with a network
Exclusion:
Inclusion:
  2. Press any button on device
GE Z-Wave Dimmers, Toggles, Outlets and Switches
Exclusion:
  1. Put hub in exclusion mode
  2. For paddle switches or dimmers, press the top or bottom of the switch
  3. For toggle switches or dimmers, press up and release the toggle switch
  4. For outlets and direct-wire modules, press the button on the device
Inclusion:
  1. Put hub in inclusion mode
Qubino RGBW Controller
(ZMNHWD1)
Factory Reset:
  1. Connect the device to the power supply.
  2. Press and hold the S (Service) button for more than 10 seconds (the white blink on LED strip, signal that the device is reset now you can release the S button)
  3. After the factory reset device will automatically attempt to re-include in the next 2 minutes.
Exclusion:
  2. Press and release the S button 3 times within 2 seconds
  3. After exclusion device will automatically attempt to re-include in the next 2 minutes.
  4. The device will be removed from your network but any custom configuration parameters
    will not be erased
Inclusion:
  3. If the device is properly included, the green LED inside the device will stay ON
Fibaro RGBW Controller
Factory Reset:
  1. Disconnect voltage supply
  2. Press and hold the B-button located inside Fibaro RGBW Controller's casing.
  3. Connect voltage supply still holding the B-button.
  4. Release the B-button.
  5. B channel will turn on (blue channel).
  6. Disconnect power supply.
Inclusion:
  1. Connect Fibaro RGBW Controller to voltage supply.
  2. Set the Z-Wave network main controller into learning mode (see
    Z-Wave network controller operating manual).
  3. Triple click the B-button or any switch connected to I1-I4 inputs.
  4. Fibaro RGBW Controller will be automatically recognized and
    included in the Z-Wave network.
Exclusion:
Ecolink Window/Door Sensor (both Z-Wave and Z-Wave Plus)
(DWZWAVE2-ECO)
Exclusion:
  1. Remove the sensor’s cover
  2. Remove the battery for at least 5 seconds
  3. Reinsert the battery
  4. Replace the cover
Inclusion:
Leviton Plug-In Outlet
(DZPD3)
Factory Reset:
  1. Hold control button until it flashes amber, and then red
Exclusion:
  2. Enter Programming Mode by holding the control button for 7 seconds, the Locator LED will turn amber
  3. Release button
  4. While it is blinking amber, tap the button one time. The Locator LED will flash green.
  5. The device is excluded
Inclusion:
  3. Release button.
  4. While it is blinking ambier, tap the control button one time. The Locator LED will flash green.
  5. Upon successful addition to the network the LED will turn off and then blink green 3 times.
  6. If the adding process is not successful the LED will flash red 3 times.
Remotec ZRC-90
Factory Reset / Exclusion:
  1. Remove battery cover
  2. Press 'R' and hold for 10 seconds
  3. Release “R” button then triple click on “R” button within 2 seconds.
Exclusion:
  1. Remove ZRC-90 battery cover
  2. Put hub into exclusion mode
  3. Press 'L' button once
  4. LED will flash slowly until complete
Inclusion:
Nexia Doorbell Sensor
(DB100Z)
Exclusion:
  2. Press and release the INSTALL button on the DB100Z.
  3. The DB100Z LED will blink rapidly for 3 seconds when it has been
    excluded from your Z-Wave network.
Inclusion:
    included into your Z-Wave network.
BULBS
All Sylvania Osram Lightify bulbs
Factory Reset:
  1. Turn OFF the light.
  2. Turn ON the light for 3 seconds.
  3. Repeat this process 5 times (OFF + ON for 3 seconds = 1 time).
  4. After the fifth time, wait 10 seconds.
  5. The light will then blink 3 times if successfully reset.
Exclusion:
  1. Delete the bulb from your hub using the IDE
Inclusion:
  1. Put hub in pairing mode
  2. The bulb should automatically be recognized.
CREE Connected Bulbs
Factory Reset:
  • Note, Cree's official instructions are incorrect. The correct procedure is below:
  1. Begin with the bulb turned off
  2. Turn the bulb ON for 1 second
  3. Turn the bulb OFF for 2 seconds
  4. Repeat steps 2 and 3 until the bulb momentarily dims (about 4 or 5 times)
  5. It will only dim for a second, signaling that it has been factory reset.
Exclusion:
Inclusion:
Sengled Bulbs
Factory Reset:
  1. Beginning with the bulb ON, quickly turn the bulb OFF and ON 10 times in quick succession (using a light switch or power strip works best)
  2. The bulb will blink 5 times when it has successfully reset.
Exclusion:
Inclusion:
The minimote is doing a "general exclusion" for the exclude, so it doesn't have to be on the same network as the other Z wave devices.
To do an include, you must first have excluded the end device so that it is a "blank slate" again.
Then the minimote must be already joined to the hubitat network. At that point, if hubitat recognizes it as a secondary controller, if it does, you will then be able to issue the include from the minimote and have it join the hubitat's network. If the minimote is still a member of your previous controller's network, the include won't work (or rather, you would be re-adding it to your previous network).
I don't know if hubitat recognizes minimote as a secondary controller or not, though.
Tagging @mike.maxwell
Yes, it's known as a secondary controller.
