I've got a contact sensor on my shed. I was checking a few things and I took a look at the in use by for the device. It says it's being used in a rule for my front lights but I can find no reference in the rule about that device. What am I missing?
I’m not seeing « Shed Door » in that rule - should I?
You may have created a condition that you're not using in the rule. Look in your Conditions section.
Make sure you “update rule” and check again.
That’s my point. The “in use by” says it’s in that rule but I can’t find it.
Ah - got it! As @danabw indicates, it may be in one of the conditions under either « Required Expression » or « Actions ».
@danabw gets the win. I didn’t think to check the conditions. Thank you
