Hi all,
I'm wondering if there are any plans for an improved media player?
I understand that it needs to work with a significant number of platforms, but it would be really good to get two features added to the existing dashboard widget if possible:
- Album art based on "currently playing"
- The ability to swipe left/right on the icon for the current song/station to move forward/back in the playlist
Does anyone know if there are plans to support something like this?
Fwiw, I've got a C5 and most of my speakers are SONOS.
OK, I'm looking into this a bit more and I've found that the MakerAPI exposes the following data when you interrogate a SONOS speaker:
"album" : "Where Will I Be? (Acoustic)",
"artist" : "Patrick James",
"audioSource" : "Sonos Q",
"enqueuedUri" : "x-rincon-cpcontainer:1006206cspotify%3aplaylist%3a2O4QEcrn4ktDdkOhM2lS5x?sid=9&flags=8300&sn=2",
"level" : "11",
"metaData" : "<DIDL-Lite xmlns:dc=\"http://purl.org/dc/elements/1.1/\" xmlns:upnp=\"urn:schemas-upnp-org:metadata-1-0/upnp/\" xmlns:r=\"urn:schemas-rinconnetworks-com:metadata-1-0/\" xmlns=\"urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/\"><item id=\"1006206cspotify%3aplaylist%3a2O4QEcrn4ktDdkOhM2lS5x\" parentID=\"00020000playlist:coffe house\" restricted=\"true\"><dc:title>Coffee House Acoustic \\u2615</dc:title><upnp:class>object.container.playlistContainer</upnp:class><dc:creator>Double J Music</dc:creator><upnp:albumArtURI>https://i.scdn.co/image/ab67706c0000bebb8487a44d13facc9b3f448f7b</upnp:albumArtURI><r:description>Coffee House Acoustic \\u2615</r:description><desc id=\"cdudn\" nameSpace=\"urn:schemas-rinconnetworks-com:metadata-1-0/\">SA_RINCON<MY ID>_X_#Svc2311-0-Token</desc></item></DIDL-Lite>",
"mute" : "unmuted",
"name" : "Where Will I Be? - Acoustic",
"station" : null,
"status" : "paused",
"trackMetaData" : "<DIDL-Lite xmlns:dc=\"http://purl.org/dc/elements/1.1/\" xmlns:upnp=\"urn:schemas-upnp-org:metadata-1-0/upnp/\" xmlns:r=\"urn:schemas-rinconnetworks-com:metadata-1-0/\" xmlns=\"urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/\"><item id=\"-1\" parentID=\"-1\" restricted=\"true\"><res protocolInfo=\"sonos.com-spotify:*:audio/x-spotify:*\" duration=\"0:04:13\">x-sonos-spotify:spotify%3atrack%3a2ICCVrvTSWLQXNFoXwIZxR?sid=9&flags=8224&sn=2</res><r:streamContent></r:streamContent><r:radioShowMd></r:radioShowMd><upnp:albumArtURI>/getaa?s=1&u=x-sonos-spotify%3aspotify%253atrack%253a2ICCVrvTSWLQXNFoXwIZxR%3fsid%3d9%26flags%3d8224%26sn%3d2</upnp:albumArtURI><dc:title>Where Will I Be? - Acoustic</dc:title><upnp:class>object.item.audioItem.musicTrack</upnp:class><dc:creator>Patrick James</dc:creator><upnp:album>Where Will I Be? (Acoustic)</upnp:album></item></DIDL-Lite>",
"trackNumber" : "20",
"trackUri" : "x-sonos-spotify:spotify%3atrack%3a2ICCVrvTSWLQXNFoXwIZxR?sid=9&flags=8224&sn=2",
"transportUri" : "x-rincon-queue:RINCON_<MY ID>#0",
"uri" : "x-rincon-queue:RINCON_<MY ID>#0"
In the {metaData}
section, there's a URL for the AlbumArt, and it seems to be XML embedded in JSON (), so it should be relatively easy to parse out?
EDIT The XML is DIDL, sample python for parsing out the Album Art is as follows:
import requests
import json
from didl_lite import didl_lite
uri = "http://<my hub>/apps/api/<app id>/devices/<device id>?access_token=<my access token>"
r = requests.get(uri)
data = r.json()
meta = json.loads(data["attributes"][1]["currentValue"])
didl = didl_lite.from_xml_string(meta["metaData"])
artwork = getattr(didl[0], "album_art_uri")
print(artwork)
This returns https://i.scdn.co/image/ab67706c0000bebb8487a44d13facc9b3f448f7b
which converts to https://i.scdn.co/image/ab67706c0000bebb8487a44d13facc9b3f448f7b
any chance you could make a driver where you put in your sonos ip address and it makes the album art available to a dashboard tile?
Interestingly, searching around for groovy didl media
found DLNA-PLAYER/Media Renderer Events.groovy at master · SmartThingsUle/DLNA-PLAYER · GitHub which presumably can be converted to a HE app/device somehow?
I can’t speak to whether or not it still works as I havent used it in a long time but someone ported it, https://drive.google.com/file/d/1-MNAPGSuMKZMqUdghC5SVkvX6Y3zxh83/view
Thanks for this, I've only just got around to testing it, I assume this replaces the current driver I'm using for my Sonos devices?
I don't own a Sonos, but I believe that is correct.
OK, thanks, I'm struggling to see the album art in the dashboard but it does seem to track the playlists etc.
