Impossible to set volume @ 0 (and mute request)
About the second loop, I want to lock automaticaly my yale 10 minutes after the entry, if the lock is still unlocked.
But that second action should be activated anytime (not after sunset), so inserting in the first loop is not correct.
Before the loop then ? Not if there is a delay of 10 minutes because the porch light loop must be activated directly and not 10 minutes after this... (because I understand that the rules are sequential and not parallel).
  1. unlock / notify / speak
  2. run the sunset porch light loop (if between sunset and sunrise)
  3. lock the yale after 10 minutes (if still unlocked)
Is it possible in one rule or should I create an independent separated rule (if still unlocked then lock it) ? I don't want to use the geofencing strategy of yale locks because I don't like geofencing for that (phone stolen ?) and non registered users could enter my home without my presence.
Btw, I discovered another problem today (posted a new one about adding a new google home into my home).
Thank you
Mike
