I have tried to add various Zigbee devices with no real success. Do I start with a dashboard or do I just add devices first?
I think Ive added a temperature sensor but all I get is a square window saying 66ºF. But in my country we use Celsius. Do you think I can even change that?
Ive used lots of other HAs but this one takes the cake. It is not intuitive, the language and devices do not help you use or install them, and I can only start the App and marvel at some squares with dashes in them.
Some simple complete sequences might help. What about…
‘Without connecting any sensors, you can get the local weather displayed on your Hubitat App main page’
OR
‘So you want to install your first Zigbee temperature sensor and have it display on the main screen in Celsius with an explanatory heading?
Why are these topics not automatically happening when you start your app for the first time?
HE has a little bit of a learning curve but once you get used to it, it is pretty easy to figure out.
My suggestion would be to look at the documentation section when you get stuck. There is a lot of good information there that will help with the majority of things you can't figure out. But you can always reach out here and there are many great people on here willing to help. I have learned a lot from just reading past posts.
Here is the link that shows the Hub Details Page which is where you can change from F to C for the hub. But keep in mind the devices you are using may only report in temp in F or C or may need to be changed on their preference page if the driver has the option.
You have to have devices added to create a dashboard that uses them. I would recommend adding all devices first.
This depends on the device and the device driver. I would start by going into the web interface for your hub (type in the hub's IP into your browser - if you did reserve the IP as suggested in the getting started guide, this would be the address you reserved or you could try hubitat.local as the address). Then select devices from the left hand menu, click on the device you want to change, and click in the preferences tab. If a farenheit/celsius conversion is available, that is likely where it would be.
Just curious if you have read any of the documentation at the link in the upper banner? Specifically, the getting started or device sections? I think this more intuitive than Home Assistant personally, especially when it comes to the automation portion of your Home Automation.
As @CaptWoody said the Hubitat learning curve can be large and the documentation is definitely a good place to turn.
However, if you are a more visual learner like myself I would suggest going to YouTube and searching for Hubitat. There are several videos ranging from adding devices to writing rules in Rule Machine. The UI has since changed but the overall principles are still the same. They would be worth giving a go when you have a few minutes.
Thanks Cap’n… I will review again the documentation. I must be getting old, but I promise not to complain again. And I am most grateful for the speedy responses to my silly novice questions, which give me some confidence that maybe I didnt make the wrong choice after all…
