Ikery 10 meter Magic Home LED RGB Strips Special:$29.23 Amazon.ca [Deal Expired]
Price: CDN$ 50.99
Deal Price: CDN$ 29.23
Ikery LED Strip Light WiFi Wireless 32.8ft/10M Smart LED Light Strip 300LED 5050 RGB Lights, Waterproof Flexible LED Strip , Music Sync, Voice Control, Compatible with Alexa Echo, Google Assistant, IFTTT home
https://www.amazon.ca/gp/product/B08169JYGC
Should work with @adamkempenich's Magic Home Wifi Devices - 0.89
RGB Controller Driver
Includes:
10 Meters (2x5) LED Strips
1 Wi-Fi Controller
1 IR Controller
3M adhesive
12V 6A Power Supply (UL Some say yes, some no)
Works like a charm with the driver :slight_smile: Thanks!
I tried now to setup the lights to turn on a sun set using rule machine. But somehow the colour is never the colour I want to have :smiley:
Do I miss something?
Screen Shot 2020-11-28 at 7.53.26 AM
I basically copied the values from the driver after setting the lights with the remote to the value I want to achieve.
Sorry, I have no idea. Might be better to ask in the Magic Home thread.
Sorry to hear about the trouble there.
You're setting Hue, Level, and CT right after one another, it looks like, which would definitely cause some unexpected results.
Have you tried just setting Hue, and seeing if that at least goes to the correct value? You shouldn't need to set all 3, you should just be able to set hue, or CT, and level.
Thanks a lot! That worked :slight_smile:
