I have 4 Ikea Repeaters but my devices seem to like to repeat thru my cheap EcoSmart Zigbee bulbs from Home Depot instead.
The Ikeas are labeled "Zigbee Repeater -". The Zigbee bulbs are Kids Bathroom A-D, Master Bath A-G, Breakfast Nook A-E and Play Room Sconce A-D. The hub is the thickness of a wall away from Master D-G and the width of the bathroom from A-C.
Knock on wood but my Zigbee mesh seems pretty stable.
Real pain to reset sometimes. I try all kinds of stuff. Holding the button down while plugging them in, holding it for a really long time, multiple presses. Stuff that isn't probably doing anything, but eventually something always gets them reset. That's all you really need. They are a pain and I dread having to reset them and re-pair. Fortunately that's been a rare need.
I used to have the same issue with them. I have since changed the driver I'm using to Markus' generic Zigbee driver instead, [Release] Generic Zigbee Drivers with Presence and Recovery, and I haven't seen them drop once since then. Disclaimer: I've only been using this driver for little over a month.
Oh, and I guess I should mention that I did upgrade my Ikea repeaters to whatever the latest firmware was at the time (using zigbee2mqtt which supports OTA updates for Ikea, not hubitat).
There has been at least one firmware update since they were originally released, so that is one possibility of why they fall off the mesh for some and not others.
But also may have nothing to do with that. Who knows? I wasn't having issues with them dropping off the network before I upgraded firmware either - so that isn't as very good data point.
Can you explain how you did it? (external power) I've some Xiaomi sensors and sometimes I need to put them in tricky places and it will be a relief if I can forgot the change of their batteries.
Thanks!
You can find various guides and tips around the forum to how to open Xiaomi Aqara and Mijia sensors. The Mijia contact sensors are the easiest to open and solder wire to for power. They look nice too and work exactly the same at the Aqara.
Would you expect the talk of device firmware updates "from HE to devices" to bode well for offering a path to doing the same you did with zigbee2mqtt ?
Hi guys, I've paired an Ikea repeater with my HE just now but it won't report its state - I've done some troubleshooting but couldn't get it to work at all:
Added a test zigbee device to HE but I was sitting centimeters away from the repeater and across the other side of the house from the HE hub yet the device wouldn't pair with the repeater which I checked under the HE's zigbee routing table
Deleted the device and re-added it
Rebooted HE
Deleted the test zigbee device and re-added it which ended up pairing with the HE hub again
Some devices are running off my bathroom hue light but I made sure I switched it off while performing the tests so that the test zigbee device wouldn't try and connect to it.
There's no status for repeaters in the driver details.
How far is that and what obstructions, reflections and objects might be attenuating the signal?
IKEA Trådfri repeaters aren't the most powerful, but these sure do sound interesting.
