Found the instructions on this site
Paired the device with Google Home, then got the pairing code to use with Hubitat. When I try to use the code in Hubitat it wont pair click the button goes to a pairing mode then within one second comes back to original screen. Ive tried it in the Android App as well
What is your "Status" under Settings > Matter Details?
Matter is enabled and status: Starting
That "Status" is the problem then. Platform version 2.4.4 has a fix. There's a beta currently ongoing if you were interested in joining, otherwise when it's released, that should help!
Platform 2.4.4 also has a built-in driver for this device, so it won't work out-of-box on 2.4.3 (or whatever you are using now), but that is a different issue.
