I've had a miserable time with button controllers.
When we moved into the house, there was a barely functional RA system, older generation stuff. For whatever reason, they located the physical switches for 8 different lighting circuits in the pantry and then had RA remotes at various locations in the kitchen for scene controls. It about 1/2 worked.
So, figure Hubitat to the Rescue. Gutted that stuff, put in GE Dimmers and Switches in the pantry. And figured that I could use button controllers in the kitchen to give my wife physical buttons in a useful location.
Its been a total failure. First, I tried Cooper RFWDC's. Those were terrible, maybe 1/3 of the time a button push led to the desired action.
So, I gave up on those. Next, Leviton VRCS4's. A little less terrible.
So, now trying Zooz Zen 32's. Still, not reliable.
Clearly, I'm doing something wrong to be having this miserable of a time.
Now, the setup I'm looking for right now is drop dead simple. I have:
GE Dimmer Switch - Undercounter Lights
GE Dimmer Switch - Recessed Lights
GE Dimmer Switch - Nook Lights
GE Dimmer Switch - Bar Lights
GE Dimmer Switch - Stove Lights
And a few more
And, what I'm trying to setup here to start with is really simple. For example, on the button controller:
Button 1: Push to turn on Undercounter Lights. Double tap to turn off
Button 2: Push to turn on Recessed Lights. Double tap to turn off
etc.
Like, really simple things here. Not even talking about having a button control multiple devices. Just ONE!
Right now, I've been trying to do this using the Button Controllers Application.
Is that the problem? Should I be setting it up completely differently?
