I'm looking to get a plug-in mains device that reports voltage.
I've seen this one 'SONOFF S60ZBTPG metering plug'.
I see the guru has a driver for it.
Does anyone know if it reacts quick enough to voltage fluctuations.
Any thoughts on this device?
I have several metering plugs, both Zigbee and Zwave. They are usually pretty chatty devices, but one way to shut them up a bit is to not report as often. If you want a quick reaction from a metering plug, you have to make it report as often as possible.
So, you really want to report only voltage when it changes at all, but not react to power or amperage. So you need a driver with a preference for only voltage reporting to report on small changes, and have amps and power react to large changes. Voltage won't change as often as amps and power, so if you are not using the plug for amps and power so much, you don't need to send the events for those very often.
One driver that does that is the Tuya Zigbee Metering Plug. It can be used with almost any of the cheap Zigbee power meters out there, I am using it for a Third Reality Zigbee Power meter.
