I have a rule for announcing what our roomba is doing. I had to remove and re add the roomba itself and now my rule says broken action. Is there any way to repair this without having to go through and build it all over again?
What happens when you clone the rule and try to configure the clone?
OH! I didn't think of that. I'll try that.
Canāt promise itāll help, but at least you can try it without further messing with the original rule.
Well now I can't get into Rule Machine at all. UGH! I'm restarting the hub....
I'm guessing where broken action is you were probably setting the variable currentstate?
I downloaded the rule but now I still can't get into RM.
You can't get into Rule Machine, or into that rule?
After I tried exporting and importing a rule, I could no longer get into RM. Sounds like the same scenario.
You might need to restore your last backup.
That has happened to me before. I suspected that this is why it is recommended to backup the hub prior to using that functionality... I happened to do that (I rarely do right before using the functionality...). Restoring the backup allowed me back in RM.
I ended up doing that and it's working now. I did have to redo some dashboard and other config work I had done since last back up but oh well
