C-8Pro Ver 2.4.3.173 main hub
C-7 2.4.3.164 primarily used to run echo speaks app
Inactive/unplugged C-8 not sure what version it was on when it was turned off
I am trying to figure out if I need to make any changes to my zigbee network
Looking at zigbee details on the C-8 Pro I have 143 devices. When I run the graph, it shows that many are repeaters.
Some of the devices are in my detached rear garage which is about 40 feet away from the Cโ8 pro hub. There are devices in that rear garage that show as being repeaters.
Mounted on the outside of that garage are two different light fixtures, both of which contain two bulbs which are currently Sengled bulbs. These bulbs seem to be problematic with staying connected. On the main house there is a similar situation. There are two separate floodlight fixtures that each have two bulbs in them also currently Sengled bulbs.
I have purchased new Third Reality bulbs to replace those eight bulbs.
If I understand correctly, the Third Reality bulbs are good repeaters whereas the sengled bulbs are not.
It was suggested that I could look at possibly using the old C-8 hub in the rear garage as a Zigby repeater only to help strengthen the network
My question is, how likely is it that the new Third Reality bulbs, compared to the Sengled ones, will be more reliable if I add them to the C-8 Pro hub without doing anything else?
The bulbs in question are on the outside of the building in floodlight fixtures that have metal shades over them so they are protected from direct moisture, but would be considered in a moist condition I guess because theyโre outside?
If I add the bulbs and there continues to be an issue, especially with the Rear ones is it a problem to add the C8 hub as a repeater only.
I am trying to avoid the headache of moving a bunch of devices from one hub over to another.
Currently the C-8 Pro and C-7 hubs are in a room, positioned less than 1 foot apart, at the back of the house next to a window with direct line of sight to the rear garage.
My thought at this point is to add the new bulbs to replace the existing ones and see what happens. If needed, repurpose the old C5 hub, as a repeater only, in the rear garage. That seems like the least amount of work.
But if anybody has any additional thoughts about whether or not I should lighten the load on the C8 pro hub Iโd appreciate any input. I could move some of the devices that are in the house over to the C7 hub and I could move all of the devices in the Rear building to the old C8 hub. And turn on hub mesh on all of those devices to talk nice to the C8 pro hub.
Replacing the bulbs requires climbing up on a ladder, which because of balance issues I can no longer do. So I need to figure out which hub the bulbs need to connect to before I enlist my friend who avoids technology to climb the ladder to screw the new bulbs in.
I appreciate any help or advice offered. Thanks in advance.
