aaiyar
January 20, 2022, 1:24am
62
In addition to the Smartly add-on that @dylan.c mentioned there are at least four other choices that are linked to below:
There is now an "official" integration for Hubitat in The Home Remote!
@AndyM has been on my case to provide one so he can retire the plugin he wrote:) That along with the recent Wink news, I have been getting a few more Hubitat requests than before so it was probably time.
This integration uses the Maker API so the setup process should be fairly straight forward for those of you familiar with it. The Home Remote will just prompt you for the IP address, App Id, Access Token, & Hub Id.
You do…
**[RELEASE] HD+ **
[image]
What is it?
A native Android app for viewing and controlling your Hubitat devices.
Features
Easy to login - 1-click login will auto discover the Hubitat Hub
Full screen - ideal for wall-mounted tablets
Keep the screen on during the day and turn it off at night (Configurable)
Flexible - fully customize the interface (icons, tile size, text size, colors)
All traffic is LOCAL to your network. No 3rd party server is used. There is also a remote access option (us…
[forum-banner]
You can now download Hubidash from hubidash.com
Hubidash is a custom standalone dashboard for your Hubitat.
Multiple user accounts with 3 different access levels for device control and dashboard settings management
Accounts are secure with sessions and a possibility to add pincodes which are required on every app load
UI customization with two themes (dark and light) and user avatars
Device tags which function as quick-access filters and groups
Device activity log
Mod…
Hi Everybody!
It has been more than two years since I've given any serious attention to HousePanel, so this is a major update. This update replaces the old hmoptions.cfg file with a database. I initially required an install of mysql but then discovered the joys of sqlite, so now this uses sqlite and no complicated installs of a database are required. You do have to have an installation of sqlite working on your server, but this comes with most Linux installations. The db file will be created fo…
All four of those developers: @bill.venhaus , @jpage4500 , @good.looking.blues , and @kewashi are super responsive to questions
Hope this helps!
Thanks @aaiyar for the links, looks like some good quality stuff to check out!
kewashi
January 21, 2022, 12:00am
64
My HousePanel dashboard has gone dormant these days but I still personally use it in my home. The version posted here still works great. If you try it out, let me know. With all that said, the built-in HE dashboards have gotten good enough these days that you probably don't need it unless you just gotta have the sophisticated customizations that are built into HousePanel. I use it because I'm all set up and am used to it. It does require a rPI to install and configure.
