I cannot connect to my C-8 locally
I didn't do nuffin!
This morning I tried to access a dashboard and could not connect to my C-8 at its IP address. I could connect via remote admin. I did a reset but that did not fix it. I did a shutdown, unplug, restart but that did not fix it. My UDMP shows the C-8 connected. I tried to connect to the diagnostic IP but no go.
What should I do next.?
Try to connect from a different browser/device?
Have you configured any VLANs on your UDMP?
Does it show it at the same IP address you're trying to connect to? Perhaps the IP address of the hub changed somehow.
I had that happen to me before I reserved an IP, but it was usually only after a reboot when it got back on the network. OP says it just happened one morning, so it seems unlikely the IP changed while it connected.
Still, going to the webpage for find my hub is an easy way to find it again if the IP did change.
Bingo!
Somehow the IP of the C-8 changed to 192.168.1.110 instead of 192.168.1.10.
I thought I had it fixed but I guess not.
That should take care of it.
Thanks!
