Hey All,
First off thanks to all of the developers out there putting drivers and apps out there for us non-programmers to use.
Ok now for my question.
I am trying to create a rule for my HVAC system (Honeywell TCC using the TCC driver).
Goal -
- Every morning I want to look at the forecast and if the forecasted (high) temp is < 45 set the thermostat "mode" to heat. If the forecased (high) is > 65 degrees set the "mode" to cooling.
- Same sequence but in the evening using the forecasted low temp.
So I am using the DarkSky app/driver to get the forecast weather and populating that into a variable %ForecastHighTemp% and %ForecastLowTemp%. My initial problem is that the low temp variable will populate but the high temp variable will not. When I manually run the rule I get a successful log entry but the value of the variable never changes.
Vars:
Log:
app:3712019-10-09 04:26:56.318 pm (http:///installedapp/configure/371)Action: Set ForecastHighTemp to Outside Weather forecastHigh
app:3712019-10-09 04:25:12.270 pm (http:///installedapp/configure/371)Action: Set ForecastHighTemp to Outside Weather forecastHigh
--- Live Log Started, waiting for events ---
Thanks for any advice...
