Hue motion sensor driver 2.2.4
Just when into the device because lightning levels were a bit hit and miss and noticed theses setting
Can anyone explain what the log settings do
There is some info here: 2.2.4 - Philips Hue Motion sensor Lux reporting updates
I haven't updated to 2.4 yet, waiting for a few hotfixes first :wink:
Ta I didn't go back far enough in my search
Hello, report battery status now?.
Thanks.
I have one normal Hue motion and one outdoor motion and they have always reported battery level.
Ok lot of thanks.
Kelo I have pair two hue motion and one report 0lux always and the other don't report, on hubitat device panel only show temperature, motion and bartery!
What can I do to report lux?, I have hub update last firmware.
I get battery and temperature and lux, however as soon as I put it back outside it it goes active and stays there, it is 3 m away from the hub through a wall
@mike.maxwell a don't want to cast aspersions, recently all my hue motion sensors have become really spoty at reporting lux values, is this something you can look into please
Play around with the new preferences in 2.2.4
I've tried setting it to 10 lux, saving ,then setting to 1 lux, but they all seam inconsistent in reporting
I have two connected, one report luz and other not, y have repair 3 times but impossible, one of them didn't retort, don't show the parameter iluminance.. Some idea?
Thanks.
Try one of the new log setting reporting options.
Do we need to save and then configure?
Absolutely do not hit configure after saving preferences.
With many drivers hitting configure may reset to default settings.
Configure should only be run once after changing drivers
That might have been it, impatience, does the device have to be awake to receive the updated settings, should I dance around in front at the same time
Most zigbee devices check for messages every 7 seconds max.
You can see the device response to the results of applied preference updates in the live logs with descriptionText logging enabled.
So this is the correct response to setting to 1 lux?
The response doesn't tell you what the value was set to, just that it was set, it's much clearer with debug logging disabled, and yes, it was set.
Why are you thinking 1 lux is what you need?
It in a stairs but the is a sky light but what the sensor sees dosnt get it directly, so when the sensor is reading over 5 it isn't needed, but when the light goes on it does hit the sensor. I need to move it but its in the best position to get movement
