Hue motion sensor does not detect motion
I updated the DTH I had in ST, and this seems to be working. Certainly no coder, but just minor changes. This does allow the "Configure" and also triggering lighting ok.
 *  Copyright 2015 SmartThings
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 *  06/07/2018 Updated for use in Hubitat, from original by "digitalgecko".
metadata {
	definition (name: "Hue Motion Sensor", namespace: "digitalgecko", author: "digitalgecko") {
		capability "Motion Sensor"
		capability "Configuration"
		capability "Battery"
		capability "Refresh"
		capability "Temperature Measurement"
		capability "Sensor"
		capability "Illuminance Measurement" //0x0400
		fingerprint profileId: "0104", inClusters: "0000,0001,0003,0406,0400,0402", outClusters: "0019", manufacturer: "Philips", model: "SML001", deviceJoinName: "Hue Motion Sensor"
	preferences {
			section {
			input title: "Temperature Offset", description: "This feature allows you to correct any temperature variations by selecting an offset. Ex: If your sensor consistently reports a temp that's 5 degrees too warm, you'd enter '-5'. If 3 degrees too cold, enter '+3'.", displayDuringSetup: false, type: "paragraph", element: "paragraph"
			input "tempOffset", "number", title: "Degrees", description: "Adjust temperature by this many degrees", range: "*..*", displayDuringSetup: false
			section {
			input title: "Luminance Offset", description: "This feature allows you to correct the luminance reading by selecting an offset. Enter a value such as 20 or -20 to adjust the luminance reading.", displayDuringSetup: false, type: "paragraph", element: "paragraph"
			input "luxOffset", "number", title: "Lux", description: "Adjust luminance by this amount", range: "*..*", displayDuringSetup: false
			input name: "debug", type: "bool", title: "Enable Debug?", defaultValue: false, displayDuringSetup: false, required: false
// Parse incoming device messages to generate events
	def msg = zigbee.parse(description)
	//log.warn "--"
	//log.trace description
	//log.debug msg
	//def x = zigbee.parseDescriptionAsMap( description )
	//log.error x
	Map map = [:]
	if (description?.startsWith('catchall:')) {
		map = parseCatchAllMessage(description)
	else if (description?.startsWith('temperature: ')) {
		map = parseCustomMessage(description)
	else if (description?.startsWith('illuminance: ')) {
//	else if (description?.startsWith('zone status')) {
//		//map = parseIasMessage(description)
//        log.trace "zone status"
	def result = map ? createEvent(map) : null
	if (description?.startsWith('enroll request')) {
		List cmds = enrollResponse()
		result = cmds?.collect { new hubitat.device.HubAction(it) }
	else if (description?.startsWith('read attr -')) {
		result = parseReportAttributeMessage(description).each { createEvent(it) }
	return result
  Refresh Function
def refresh() {
	log.debug "Refreshing Values"
	def refreshCmds = []
	refreshCmds +=zigbee.readAttribute(0x0001, 0x0020) // Read battery?
	refreshCmds += zigbee.readAttribute(0x0402, 0x0000) // Read temp?
	refreshCmds += zigbee.readAttribute(0x0400, 0x0000) // Read luminance?
	refreshCmds += zigbee.readAttribute(0x0406, 0x0000) // Read motion?
	return refreshCmds + enrollResponse()
  Configure Function
def configure() {
// TODO : device watch?
	String zigbeeId = swapEndianHex(device.hub.zigbeeId)
	log.debug "Confuguring Reporting and Bindings."
	def configCmds = []
	configCmds += zigbee.batteryConfig()
	configCmds += zigbee.temperatureConfig(60, 600) // Set temp reporting times // Confirmed
	configCmds += zigbee.configureReporting(0x406,0x0000, 0x18, 10, 600, null) // motion // confirmed
/* Default Orginal Code
	configCmds += zigbee.configureReporting(0x406,0x0000, 0x18, 30, 600, null) // motion // confirmed
	// Data type is not 0x20 = 0x8D invalid data type Unsigned 8-bit integer
	configCmds += zigbee.configureReporting(0x400,0x0000, 0x21, 60, 600, 0x20) // Set luminance reporting times?? maybe
	return refresh() + configCmds
	getMotionResult
private Map getMotionResult(value) {
	//log.trace "Motion : " + value
	def descriptionText = value == "01" ? '{{ device.displayName }} detected motion':
			'{{ device.displayName }} stopped detecting motion'
	return [
		value: value == "01" ? "active" : "inactive",
		descriptionText: descriptionText,
		translatable: true,
  getTemperatureResult
private Map getTemperatureResult(value) {
	//log.trace "Temperature : " + value
	if (tempOffset) {
		def offset = tempOffset as int
		def v = value as int
		value = v + offset
	def descriptionText = temperatureScale == 'C' ? '{{ device.displayName }} was {{ value }}°C':
			'{{ device.displayName }} was {{ value }}°F'
	return [
		value: value,
		translatable: true,
		unit: temperatureScale
def getTemperature(value) {
	def celsius = Integer.parseInt(value, 16).shortValue() / 100
	if(getTemperatureScale() == "C"){
		return Math.round(celsius)
		} else {
			return Math.round(celsiusToFahrenheit(celsius))
private Map getLuminanceResult(rawValue) {
	log.debug "Luminance rawValue = ${rawValue}"
	if (luxOffset) {
		def offset = luxOffset as int
		def v = rawValue as int
		rawValue = v + offset
	def result = [
		value: '--',
		translatable: true,
		unit: 'lux'
	result.value = rawValue as Integer
	return result
	getBatteryResult
//TODO: needs calibration
private Map getBatteryResult(rawValue) {
	//log.debug "Battery rawValue = ${rawValue}"
	def result = [
		value: '--',
		translatable: true
	def volts = rawValue / 10
	if (rawValue == 0 || rawValue == 255) {}
	else {
		if (volts > 3.5) {
			result.descriptionText = "{{ device.displayName }} battery has too much power: (> 3.5) volts."
		else {
			if (device.getDataValue("manufacturer") == "SmartThings") {
				volts = rawValue // For the batteryMap to work the key needs to be an int
				def batteryMap = [28:100, 27:100, 26:100, 25:90, 24:90, 23:70,
								  22:70, 21:50, 20:50, 19:30, 18:30, 17:15, 16:1, 15:0]
				def minVolts = 15
				def maxVolts = 28
				if (volts < minVolts)
					volts = minVolts
				else if (volts > maxVolts)
					volts = maxVolts
				def pct = batteryMap[volts]
				if (pct != null) {
					result.value = pct
					result.descriptionText = "{{ device.displayName }} battery was {{ value }}%"
			else {
				def minVolts = 2.1
				def maxVolts = 3.0
				def pct = (volts - minVolts) / (maxVolts - minVolts)
				def roundedPct = Math.round(pct * 100)
				if (roundedPct <= 0)
					roundedPct = 1
				result.value = Math.min(100, roundedPct)
	return result
	parseCustomMessage
private Map parseCustomMessage(String description) {
	Map resultMap = [:]
		def value = zigbee.parseHATemperatureValue(description, "temperature: ", getTemperatureScale())
		resultMap = getTemperatureResult(value)
	log.warn "value: " + description.split(": ")[1]
			log.warn "proc: " + value
		def value = zigbee.lux( description.split(": ")[1] as Integer ) //zigbee.parseHAIlluminanceValue(description, "illuminance: ", getTemperatureScale())
		resultMap = getLuminanceResult(value)
	return resultMap
private List parseReportAttributeMessage(String description) {
	Map descMap = (description - "read attr - ").split(",").inject([:]) { map, param ->
		def nameAndValue = param.split(":")
		map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
	List result = []
	// Temperature
	if (descMap.cluster == "0402" && descMap.attrId == "0000") {
		def value = getTemperature(descMap.value)
		result << getTemperatureResult(value)
	// Motion
	else if (descMap.cluster == "0406" && descMap.attrId == "0000") {
		result << getMotionResult(descMap.value)
	// Battery
	else if (descMap.cluster == "0001" && descMap.attrId == "0020") {
		result << getBatteryResult(Integer.parseInt(descMap.value, 16))
	// Luminance
	else if (descMap.cluster == "0402" ) { //&& descMap.attrId == "0020") {
		log.error "Luminance Response " + description
		//result << getBatteryResult(Integer.parseInt(descMap.value, 16))
	return result
private Map parseCatchAllMessage(String description) {
	Map resultMap = [:]
	def cluster = zigbee.parse(description)
//	log.debug cluster
	if (shouldProcessMessage(cluster)) {
		switch(cluster.clusterId) {
			case 0x0001:
				// 0x07 - configure reporting
				if (cluster.command != 0x07) {
					resultMap = getBatteryResult(cluster.data.last())
			break
			case 0x0400:
				if (cluster.command == 0x07) { // Ignore Configure Reporting Response
					if(cluster.data[0] == 0x00) {
						log.trace "Luminance Reporting Configured"
						sendEvent(name: "checkInterval", value: 60 * 12, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
					else {
						log.warn "Luminance REPORTING CONFIG FAILED- error code:${cluster.data[0]}"
				else {
					log.debug "catchall : luminance" + cluster
					resultMap = getLuminanceResult(cluster.data.last());
			break
			case 0x0402:
						log.trace "Temperature Reporting Configured"
					else {
						log.warn "TEMP REPORTING CONFIG FAILED- error code:${cluster.data[0]}"
				else {
					// temp is last 2 data values. reverse to swap endian
					String temp = cluster.data[-2..-1].reverse().collect { cluster.hex1(it) }.join()
					def value = getTemperature(temp)
			break
	return resultMap
private boolean shouldProcessMessage(cluster) {
	// 0x0B is default response indicating message got through
	boolean ignoredMessage = cluster.profileId != 0x0104 ||
	cluster.command == 0x0B ||
	(cluster.data.size() > 0 && cluster.data.first() == 0x3e)
	return !ignoredMessage
// This seems to be IAS Specific and not needed we are not really a motion sensor
def enrollResponse() {
//	log.debug "Sending enroll response"
//	String zigbeeEui = swapEndianHex(device.hub.zigbeeEui)
//		//Resending the CIE in case the enroll request is sent before CIE is written
//		"zcl global write 0x500 0x10 0xf0 {${zigbeeEui}}", "delay 200",
//		"send 0x${device.deviceNetworkId} 1 ${endpointId}", "delay 500",
//		//Enroll Response
//		"raw 0x500 {01 23 00 00 00}", "delay 200",
//		"send 0x${device.deviceNetworkId} 1 1", "delay 200"
def configureHealthCheck() {
	Integer hcIntervalMinutes = 12
	refresh()
	sendEvent(name: "checkInterval", value: hcIntervalMinutes * 60, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
def updated() {
	log.debug "in updated()"
def ping() {
	return zigbee.onOffRefresh()
private def logging(message) {
	if (settings.debug == "true") log.debug "$message"
private getEndpointId() {
	new BigInteger(device.endpointId, 16).toString()
private String swapEndianHex(String hex) {
	reverseArray(hex.decodeHex()).encodeHex()
private byte[] reverseArray(byte[] array) {
	int i = 0;
	int j = array.length - 1;
	byte tmp;
	while (j > i) {
		tmp = array[j];
		array[j] = array[i];
		array[i] = tmp;
		j--;
		i++;
	return array
